C130MARINE
- Aug 21, 2007
- Reaction score
- 0
- Location
- ft worth Texas
- 1991 Ranger STX
- Automatic
Gents, im in a bit of a jam. I really could use some guidance. Okay I have a 91 Ranger ext cab STX I put a lot of lift on the truck. I ground down all the factory rivits and installed all the new brackets. Then reassembled everything. Now, I also extended the radius arms. not being a real "4 wheel drive guy", I thought I did pretty well. Well seems my ball joints have worn out pretty quickly...so I started doing some investigating. Even though I extended my radius arms, I still need to drop them or ext them more. The Dana 35 was leaning forward about -10 degrees. Which is about 13 to 17 degrees out of wack. SO my question is with the radius arms disconnected from the frame you can slide the dana forward or backward 2-3 inches. So I need to understand how to position the Dana and then where to mount the radius arms. I want the radius arms to be mounted within a 1/4 inch of each other since they aren't adjustable ends, and I was told if not very close the truck will pull one side or the other! Somethings that would really help me are, 1)what is the stock length of a radius arm that hasn't been modified? a measurement from center of the bolt that mounts it to the beam to the very last thread that used to go through the ford cradle type mount. The other problem I have is that the way the radius arms were mounted, the front coil springs both bowed at the bottom. like the top spring bucket was not exactly inline with the bottom bucket. More like the top bucket was 2 inches behind the bottom bucket. the springs would be straight until like the 3rd or 4th coil then bend back and from there the spring would be at an angel until it met the top bucket. so I put a cargo strap on each side of the dana and cranked it back to where the lower bucket looked as it aligned with the top bucket. the beams look straight from the pivot point to the spindle. so the steering doesn't seem to bind and it looks like everything is fairly centered. the coil is almost perfectly straight. huge improvement from before. or so I think....can anyone help me out???? Im looking for advice where on the frame should I mount radius arm brackets...meaning I think I ext these arms 12" total. so if I could get a stock length I would know for sure how much longer mine are. then maybe I could measure from the original holes and fig how far back. And how do I find out how my front rear should sit? Im pretty lost and need help. I would appreciate any input you have. thanks again.
Respectfully,
Dale
Respectfully,
Dale
