Please help....
4
High shoals
Ford ranger
None
None yet.
15 inch
Please help.... I am at a loss, the starting circuit on my 90 ranger 2.3 liter isn't working. I have changed the starter, ignition switch, solenoid, and eec relay. I don't know what else to do. Any suggestions will be appreciated.
superj
3,040
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
Do you get power at the relay when the key is turned? How about at the starter?
2011Supercab
506
Washington
Toyota Tacoma
Clutch Safety Switch ?
4
High shoals
Ford ranger
None
None yet.
15 inch
I changed the clutch safety switch last year. I haven't checked for power at the relay yet. But will. I can put a jumper wire at the solenoid to get it started. It runs just fine. I just can't get power to the ignition wire at the solenoid.
RobbieD
2.9l Mafia
3,779
Georgia
That's where I'd look, too.
The clip that holds the NSS is kind of mickey mouse; the switch may just be out of adjustment.
4
High shoals
Ford ranger
None
None yet.
15 inch
I don't get power at the relay. Just checked it.
4
High shoals
Ford ranger
None
None yet.
15 inch
I guess what I should ask is, what fusible link is for supplying power to the eec relay and where exactly is it located?
RobbieD
2.9l Mafia
3,779
Georgia
You said it will run if you start it by jumping the starter relay. If so, chances are that it's not the EEC relay.
It sounds like your problem is in the starting circuit. There's basically only 3 components in the starting circuit- the ignition switch, the clutch safety switch and the starter solenoid.
Check power in, and then power out, of the clutch safety switch.
Fix the "no start" condition first, then see where you're at.
4
High shoals
Ford ranger
None
None yet.
15 inch
I got it running. It was the ignition solenoid. I bought one from Amazon and it didn't work. So I went and got yet another one. Last time I buy electrical parts from there.
ekrampitzjr
1,142
Virginia
Amazon and eBay are building quite the reputation for bad and counterfeit parts.
rusty ol ranger
2.9 Mafia-Don
8,038
Michigan
177 CID
Ive had better luck with ebay then amazon.
I ordered a starter switch/light switch combo for my polaris quad from crapazon, i went to push up on the starter switch (how you engage the starter) and the whole thing came apart.
DeeRanger
42
Pennsylvania
I don't much like buying from Feebay or Scamazon, but that's about all we're left with today for certain items.
Uncle Gump
Boomers gotta Boom
TRS 25th Anniversary
14,027
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
It's all a buyer beware...
scotts90ranger
4,861
Dayton Oregon
2.3 Turbo
Honestly your odds of getting a good part are only like 10% better even buying from an auto parts store and like 20% better getting stuff from a dealer anymore too, overall quality of anything is down the crapper...
TexasDuck66
July Truck of The Month
