Planning a 2.0 to 2.9 swap in my 1984 2wd, auto trans
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
85 Mustangs with automatics and all 85 Crown Vics had CFI, not carburetors, but if you find one and want to, a 2 barrel carb will work on a CFI intake. 81 and earlier 302's, all 289's and 351's had 28.2 oz crank imbalances and 82 and newer 302's had 50 oz imbalance- keep that in mind buying a flywheel, get it wrong and it'll shake your teeth out(and the main bearings). 82 and later 302's used a one piece rear main seal which I greatly prefer. 85 and later Mustangs had roller cams and other models got them later- worth having because of reduced parasitic drag and not needing oil with zinc and phosphorous(zddp). Unless you find one that's pristine and free, I'd avoid 73-76 302's- Ford increased the deck height by .023" to drop the compression, the cam gears were retarded, and the heads used rail rockers which beat the valve guides to death. Actually, just plain avoid them. A roller cam mandates a hardened distributor gear and you have to drill through the distributor shaft to pin it in place, if the gear has ever been replaced the shaft already has 2 holes in it and it's junk. I bought a new Pertronics distributor for that reason instead of a reman Duraspark which would have needed a new gear. 96 Explorers came with GT40 heads which I prefer, 97's had GT40p heads which are good but limit exhaust manifold/header choices, and the E7TE heads used by most models are pretty good and plentiful-that means cheaper. As I understand, T birds and Explorers had the front drive brackets and pulleys that work best, I used fox Mustang brackets and had to mount the radiator inside the core support. A T bird or Explorer engine is apt to have been treated more gently than a Mustang. This swap is doable but it's not a bolt in, overhaul everything so you have to put in together once.Good luck.
Ramcharger90
1,708
N/A na
306, Bcam,
Honestly if you decide to go EFI 5.0 get the engine/computer from a 88-93 Mustang it was 11 wires to merge my 90's harness in..... but with a carb setup a roller 302 with a 4 barrel and a HEI distributor is a decent setup.
Ramcharger90
1,708
N/A na
306, Bcam,
Ask yourself what is the end goal?
rusty ol ranger
2.9 Mafia-Don
7,491
Michigan
177 CID
Dude.....
Go find a carbed 302 (they are a dime a dozen) and swap it in.
As far as carb choice are you after all out performance or reliabilty/driveabilty?
Its important to remember that a stock, probably late 70s wheezing 302 isnt going to need a 750 double pumper bolted ontop of it. So dont fall into that trap.
Heres what i would do...
Late 70s 302 block (cheapest to obtain, grab the duraspark goodies)
Slightly more bumpy cam, but not to crazy, straight up (pre emission) timing set.
Headers/intake/edelbrock 600cfm 4bbl along with rebuilt internals.
Youll have substantially more power then your 2.0, and come pretty close to the mileage of a 4.0 (espicially if you run an M5OD), your stock 7.5 in rear will be fine with it, and it wont be *that* costly and itll save you the headache of going to EFI.
I love the 2.9...itll stomp a 2.0 into dust then piss on the remains, but a carbed 302 would actually be eaisee and net much larger gains.
If you really feel froggy...a 351W would also go in with a bit more work
neinnein_nein
30
new york
ford ranger
soon-to-fire up 2.3 turbo lima
3!!
Damn it i was too stupid to find the “page 2” button until now. Processing this new stuff. Thanks for the suggs. my main question of course now I where do I go to pull an engine trans and what do I find it in. might go look at someone’s monster truck project they are trying to get rid of in the next few days. It’s a 351 on an old bronco frame, with a ranger crew cab body on it and a five foot lift or something. my main problem with that is tht it’s crew cab and looks awesome, and that deep down I just want TWO TRUCKS, and that’s not the idea here..
neinnein_nein
30
new york
ford ranger
3!!
Dude.....
kind of a dumb, practical question but since I’ve never done it: whats the best place to find a late 70’s 302 without buying an entire old car? Showing up at a junkyard with my tools, a friend and an engine lift right?
All eBay seems to have is insane $4K rebuilt 302’s with chrome alternators etc.
I’m necessarily not into all-out performance, I use the truck all the time to move stuff around and if I can get this done quickly I want to drive cross country again and a V8 that could handle AC and more speed/more towing power/sound better/massage my autism during the swap lol
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
70's 302s had crap compression. Your better off getting a late 80s-90s which would have better compression and a roller cam. Even if you get an EFI engine you can just throw an edelbrock or whatever carb intake manifold on it.
Plenty of u pull junkyards in new york...
neinnein_nein
30
new york
ford ranger
3!!
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Gary is a good guy, call Gary.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
42757
Gary's tried to murder me quite a few times.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Good call on the Gary's lol.
neinnein_nein
30
new york
ford ranger
3!!
Gary’s 4x4 transmission wouldn’t really work on my truck tho right? Would an A4LD work? I see one nearby on Craigslist.. with basically an entire 2.3L engine plus exhaust ac etc for 500 bucks..
Also can anyone recommend an engine hoist that’s not 100% crap but also not too good since I’ll most likely be using it just 2-3 times. Harbor FReight?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
You can't put an A4LD behind a 302. The explosion would be visible from the space station...
rusty ol ranger
2.9 Mafia-Don
7,491
Michigan
177 CID
@neinnein_nein 302s can be found in basically everything. The reason i suggested a late 70s motor was you could steal all the duraspark stuff along with it.
Your best bet finding a 302 will be an F100, or boxbody crown vic.
If you go with an EFI block the easiest place to locate one is a 87-96 F150 4wd.
Crown vics/marquis ran them EFI from 85-91, and if your yard (or you) doesnt mind a project the 302 was common in 1/2ton Econolines aswell
