Innocent Fool
- Jun 18, 2018
- Reaction score
- 4
- Location
- ND
- Make / Model
- Ford
- Manual
2003 FX4 Level 2 with 8.8, 31 spline rear diff. having trouble with the pinion nut backing out.
Almost looks like oil is running past the threads of the nut causing it to come loose (?)
Tried putting black RTV on the pinion threads and back of nut before torquing down, Worked for a short time but happened again.
Tried putting an O-ring over the pinion shaft and torquing down which helped the longest but still same issue.
Continuing to have issues with the pinion nut loosening up causing play in the pinion which takes out the pinion seal.
Have replaced the seal 3 times and in the last 8000 miles and it just happened again.
All times nut was torqued to spec with torque wrench.
Is there some secret to keeping the pinion nuts tight?
