- Jun 10, 2003
- 131
- Age
- 36
- Toledo, Ohio
- Ford
- Engine Type
- V8
- Engine Size
- 5.8l
- 2WD / 4WD
- 2WD
I'm getting ready to swap an explorer axle onto my truck. I got it up on stands and realised things aren't quite what I thought they should be. My pinion on my current axle is pointed up quite a bit more than I thought it would have been. I've got 4" lift leaves and no stock block. The springs have a wedge bolted to the bottom though.
So my question, the flange on the tcase and the flange on the pinion should be on parallel planes, correct? Should I just make my new axle fit right or should I try to figure out why this angle is so far out of whack first? I don't want this issue to come back and haunt me next time I change my rear suspension. I've thought about adding lift shackles but that would only throw the angle off even more. Should I pull off that wedge before I put the new axle in?
Sent from my HTCEVOV4G using Tapatalk now Free
