Pics of my v8 ranger project
Bird76Mojo
1,265
IL
i m assuming yours has an 8.8 in it by now?
I used an 8.8" axle from a 2004 FX4 LVLII Ranger so I could get the Torsen and the 31 spline shafts. Explorer Limited aluminum driveshaft that I had shortened.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Spray paint the seats with fabric paint.
svtcards
137
Lyman maine
302
3'' front 4''back
any direct bolt in blacks seats out there instead of the blue ones?any explorers came black that would work?seats up to 98 explorers will bolt up correct?
svtcards
137
Lyman maine
302
3'' front 4''back
that fabric paint makes the material feel like crap i think.the seats r pretty nice besides being blue
svtcards
137
Lyman maine
302
3'' front 4''back
did u have to narrow the rearend?or did u leave it the way it was?how much hp can a ranger 8.8 handle?
svtcards
137
Lyman maine
302
3'' front 4''back
i hope i can use my stock drive shaft,and not need ing to shorten it
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Mustang or escort seats may bolt in idk. There is a Fusion with black pleather seats in good shape at the Pick-N-Pull i would like to get, but dont know if they will bolt in with no fab or mods
svtcards
137
Lyman maine
302
3'' front 4''back
What yr mustangs?
Bird76Mojo
1,265
IL
I didn't shorten it, but it could use about 1.5" taken off of each side. That's only because of the offset on the rims I run though..
The 31 spline 8.8 should theoretically be able to handle as much as a 9" Ford axle. The axle shafts are very close to the same diameter, and so is the ring gear. That's where they get their names from..
I've read build threads where guys were building and running drag cars, and their 28 spline 8.8" axles were handling 400hp regularly. So the 31 spline should be even stronger.
The 8.8" axle is actually heavier (lbs) than the 9", and most people like the 9" for easier gear changes, and getting rid of the c-clips.
svtcards
137
Lyman maine
302
3'' front 4''back
Nice!so I should b all set with my 28 spline 8.8 then.very info.thanx again man
Ramcharger90
1,708
N/A na
306, Bcam,
I think 2000 BMW x5 seats work from what I've heard
