Performance issues.
JohnAllen
7
Woodstock, GA
Ford Bronco2
6"
33x10.50r15
Has anyone else ran into this issue. When I crank my truck she does the warm up almost flawlessly. As soon as I touch the clutch she idles back up to about 2grand. I tap the brake, she idles back down to about 1200. When I start driving it'll act about the same and when going up hill (55mph and up) in 5the gear, she loses momentum quickly, no matter the incline. Down shift back to fourth and she'll start picking back up slightly. It does have a lean code and I've changed everything from emissions to fuel system, and checked for vacuum leaks with no luck. Any help would be highly appreciated.
rusty ol ranger
2.9 Mafia-Don
7,485
Michigan
177 CID
Unhook your brake booster vacuum line and plug it off. You wont have power brakes but see if symptoms improve. You may of blown a booster
JohnAllen
7
Woodstock, GA
Ford Bronco2
6"
33x10.50r15
Ok, I'll give it a shot.
JohnAllen
7
Woodstock, GA
Ford Bronco2
6"
33x10.50r15
Checked that booster and it nor the hose was bad. Don't know what else it could be. Guess just an old motor. Thank you tho.
rusty ol ranger
2.9 Mafia-Don
7,485
Michigan
177 CID
Checked that booster and it nor the hose was bad. Not know what else it could be. Guess just an old motor. Thank you tho.
Run a compression test/vacuum test. I doubt thats the issue though, but itll put your mind at ease. Honestly 2.9s run literally forever as long as you dont overheat them.
Have you checked for codes?
JohnAllen
7
Woodstock, GA
Ford Bronco2
6"
33x10.50r15
Yes I have. I keep getting the code for the neutral switch on the trans (FM146) and a lean code. Unfortunately she has been ran hot a few time, I keep having problems with the connectors on my electric fan going out.
rusty ol ranger
2.9 Mafia-Don
7,485
Michigan
177 CID
Ignore the neutral code...that just means its in gear while youre testing.
Getting a 2.9 hot isnt good...youre not losing antifreeze with no obvious leaks right?
JohnAllen
7
Woodstock, GA
Ford Bronco2
6"
33x10.50r15
No sir. No oil where it shouldn't be either.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Interesting. Can you test the resistance of your coolant temp sensor and intake air temp sensor? Both cold and warmed up.
JohnAllen
7
Woodstock, GA
Ford Bronco2
6"
33x10.50r15
Not right now. But I'll be able to test them warm when I get home and then cold in the morning.
rusty ol ranger
2.9 Mafia-Don
7,485
Michigan
177 CID
This is a non EGR 88+ 2.9 correct? I assumed that by the BII in your avatar. If its a 86/87 with an EGR that could be the culprit.
JohnAllen
7
Woodstock, GA
Ford Bronco2
6"
33x10.50r15
Yes sir. It's an 89 xlt.
JohnAllen
7
Woodstock, GA
Ford Bronco2
6"
33x10.50r15
Warm: Air temp is 4.40 and coolant temp is 2.98
JohnAllen
7
Woodstock, GA
Ford Bronco2
6"
33x10.50r15
Just did the codes and koeo is (first set) 67. (Second set) 41, 54, 63. Koer (first set) 1. (Second set) 41, 77
JohnAllen
7
Woodstock, GA
Ford Bronco2
6"
33x10.50r15
Ok, so this piece that has the three small vac lines, I changed its location from off the motor to my air box and now she's idling better. And the codes changed to 23 (tps to high or throttle adjusted to high) but she's idling between 700 and 800. I still have the 41 code too, but that's it.
