Maui Cruiser
- May 3, 2018
- 0
- Ford
Aloha from Maui,
I picked up a 2001 3.0L Ranger 155k miles.
Cleaned up the battery connectors and removed some sound system wiring from the positive side.
No crank no start, PATS light flashing quickly.
5 chimes, with the slow flash code just giving 1's.... 1-1....1-1.....1-1.....
Story from previous owner was that someone was messing around in the steering column, which makes me thing that they somehow fried the PATS transceiver...
There are 12 volts at the plug for the transceiver, so it has power... There is also power going to fuel pump, so the PCM must be intact.
My question is:
Since the key was working for this vehicle, and the Theft light is flashing fast, does that mean the PATS light is flashing because the transceiver is fried?
They're cheap enough so I'm happy to Amazon a new one and try it out, assuming it just transmits whatever the key chip has on it.
Also, does the key have a battery in it that might just need replacing? I pulled it apart but it looks sealed off with some waterproofing situation.
Any help much appreciated boys!!!
My question is:
