Part number/source request - cab floor support
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Alright, I have the last rot area to fix.
Need the rear crossmember for a 1988 extended cab. I don't know what to call the crossmember. Floor support, maybe? It's the sheet metal section of the cab that attaches to the cab mounts on the frame. Mine is TOAST.
Found one online for $120. Absolutely not paying that for one.
I "think" it's number seven on the diagram. Maybe number six?
Found the part number here, but bit not sure it will fit my 1988:
Any sources or ideas as to a replacement one I can weld in is welcome. Preferably less than $120. Only need a partial for the drivers side. Upgraded from a Flux core to a Hobart Handler 160, so should be a little easier to weld sheet metal. :icon_thumby:
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
The flux-core is great for dirty metal, like exhaust. But is a pain to clean the spatter.
The part number you posted starts with f8 which is 1998. I think they made the cab 3" longer in that year compared to the 88, but it would probably not affect the cross-member other than placement 3" farther back on the frame....BUT not sure.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
From what I can tell, the crossmember / floor support is the same 1983-2011
86merc5.0
10
Clarksville, Tn
I've never changed one, but would you be able to get one from a scrapyard or a wreck at a bodyshop ( just thinking of situations were the cab would already be removed ) good luck.
Rangerx2
27
Pennsylvania
3.7 V6
Always question authority
Have you tried LMC Truck Parts? Surprisingly they have a good selection of parts for these early Rangers.
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
