samsonitesamsonite
- Jan 5, 2003
- 3
- Age
- 36
- Bellingham, Wa
- Jeep
- Engine Size
- 2.5
What do you guys know about em? are the any good? I found these
The definition of a parabolic springs
They look like this :
What is a parabolic spring?
Basically a DuraTrail Parabolic Spring is a spring that consists of two or more leaves. The leaves touch only in the center, where they are fixed to the axle and at the outer ends, where they are fixed to the vehicle. In between those two points the leaves do not touch each other as they do with conventional leaf springs.
Each leaf represents a complete spring in it's self and will act as such. To enable this the leaf is tapered, from the center (thick) to the outer ends (thin). This tapering is parabolic, it means that every centimeter (or inch) the thickness of the leaf decreases in an amount that relates to the square function of it's length.
