Painting truck looking for ideas
Kingoverace
Jersey
EFI 5.0
yah...only leave the cap on when its needed....I wonder about a 2 tone, like gray on bottom and black above the pin stripe.....Or some color variation like that...
However I've admired super glossy black trucks lately... idk, prob just thinkin bout a 78 Bronco I saw recently.
thebigyellowtruck
New Boston, MI
2.3L 4 cylinder
how about bed liner over the POR, then you won't have to undercoat it ever. just another thought.
have you heard of any good bed liners to do this with? i have only ever sprayed raptor liner as an undercoat, but i never heard back from the people who trucks i sprayed that on.
thebigyellowtruck
New Boston, MI
2.3L 4 cylinder
if i paint the truck, im gonna paint the cap to match. i will try to get some one to photoshop ur black on top gray on bottom paint scheme. you wouldnt happen to have a pic i could referance do you?
02RangerXLT
53
NE
I would use Linex, they're using it to spray frames of semi's, should hold up very well.
thebigyellowtruck
New Boston, MI
2.3L 4 cylinder
i was thinking herculiner. i guy easily get that and just brush it on. i just dont think that will hold up well. Does anyone know of bedliners i can buy and spray myself as an undercoat?
master hec0
5
okotoks alberta canada
4.0L V6
once i have the funds i will be bedlining the outside of my bronco. its better to roll on since it goes on thicker
herculiner and duplicolor sell diy roll on liner
thebigyellowtruck
New Boston, MI
2.3L 4 cylinder
ive definatly been sold on the bedliner. i know the spray on stuff ive used before went on pretty thick. a lot thicker than i have seen rolled on herculiner. maybe the duplicolor is thicker?
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
did the duplicolor. got a bad can and it was a pos! got a full refund, plus acetone to clean it all off. i'd stick with Herculiner especially if you're brushing it on. and 2-3 thin coats is way better then one thick one when doing it. build it up slowly to the thickness you want. one thick coat and it will start chipping off in no time. also, keep in mind that the POR-15 will have a glossy finish that will need to be scuffed up and dulled good before the bedliner goes on. lotta work, but more than worth it in the end... imho.
thebigyellowtruck
New Boston, MI
2.3L 4 cylinder
i was thinking the same thing. With how much work im gonna put into this truck and the time frame in which im gonna do it in, i dont wanna cut any corners. my plan is to start once i get out of school. once i start im hoping to be done in 3-4 weeks start to finish.
strvger
19
2.3
how about this... instead of all that sanding, just try using some self-etching primer on the POR and see if that holds well enough for the bedliner to go right over that. that would save tons of time and energy.
thebigyellowtruck
New Boston, MI
2.3L 4 cylinder
thats a good idea. im gonna make a few calls and see if the painters i know have tried anything like that too.
HareRazor
Montezuma
I used the duplicolor spray on/ roll on truck bed liner and i sanded, scuffed the inside of the bed and cleaned it alll good and that stuff all peeled off in a couple of months
93rangerguy
Foster, RI
i would pick a color but paint it with a reaction job. paint it in steps like 100 % paint then 75% paint 25 clear and 50 50 then 25 paint 75 clear then 10 % paint and 90 % clear. Shines like a basterd and looks beautiful in candy red. If you keep the color scheme theirs less sanding!
