Thanks for the info, still learning here.... When first replaced the fuel pump the light came on the first time within a few miles. Once I tightened the gas cap and cleared the light it didn't come on again for a couple hundred miles.
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
The fuel system has to be totally sealed, or it will fail. If you go to the station and fill the tank all the way to the top, and gas starts leaking out around the sending unit, then yes that is a problem.Being new to Fords and dealing with this issue for the firs time I started looking around yesterday hoping to see an obvious issue before I take the bed off again. Looking between the bed and the cab a portion of the fuel pump barely is visible. The gasket/o ring I put on is a green color and I noticed I could see part of it in that area between the top of the tank and the metal locking ring that holds the fuel pump down. I honestly cant remember when I took it apart how the fuel pump and gasket all fit together at the top of the tank. If the locking ring is not seated correctly cold that cause this code. I have watched a few youtube videos but can't really see any angles that show if the o ring is visible in spots or not.
I know when I put the lock ring on I had the fuel pump pushed down and made sure each slot was into place when I tapped it into position.
I had a terrible time with my sending unit leaking on my old Tahoe. It had a plastic tank, but those ears like in your picture were steel. They were molded into the tank and had rusted. The rust had bulged out and deformed the opening where the o-ring goes, and it would not seal. In this case I could not find another tank and ended up revamping the whole fuel system with a 2dr Tahoe tank mounted at the rear. It was a steel tank and easy to get. What a can of worms that turned out to be. But I finally got it.Thank, on mine there is no plastic retaining ring. Just the metal lock ring like in the screenshot I posted above.
