BULLA
- Feb 19, 2023
- 2
- Louisiana
- Ford Ranger
I have a 2002 ranger with the 4.0 auto that was given to me by my brother. He lost the key and after about a year of sitting he gave it up. So I had a key programmed for it and it wouldn’t start. Through some troubleshooting I found the fuel pump was out. Replaced fuel pump and it fired right up. Now my dad had told me it was leaking oil and boy was it. But it also had a miss. So I decided to pull it in the shop to change the valve cover gaskets. Not the hardest but not the easiest job! Well I figured since it had the miss I’d also replace the spark plugs and the injectors. Figured one of those would be my culprit. Long story short I got it all reassembled and the moss is still there. Now I almost could guarantee which cylinder was gonna be the problem it the beginning cause #5 had lots of carbon build up in the intake and that spark plug looked the worst. Now since I had cleaned everything and new injectors and plugs I started pulling wires off of the coil. Sure enough number 5 wouldn’t change a thing. So I pulled that plug and it was wet. At this point I thought it didn’t have fire to that plug. So I cranked the truck with that plug out and there was plenty of fire. So I opted to pull the number 6 also. I checked it for spark and it was the same. Then I decided to do a compression test. Both cylinders tested 150psi. I reassembled everything and swapped the #5 plugs just for good measure and no change. So now I’m wondering could it be a bad injector that just so happened to be on that same cylinder that originally seemed to be the problem. Trying to be through. I have read of a leak down test though never performed one. Guess I need to look into it.
