CeodilEQ
- Apr 30, 2024
- 1
- Bowling Green KY
- Ford Ranger XLT
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L SOHC
- 2WD / 4WD
- 2WD
I have a 2005 Ford Ranger XLT 4.0L automatic, recently replaced timing and head gaskets due to the timing guide breaking on bank 1 on the drive home. I used a Cloyes timing kit replaced all gears guides chains and tensioners, I used the proper tool to hold the cam in place to time the motor and all went well. I finished everything up put everything back in and test drove the truck and it was fine I put 500 miles on it and then someone stole all 3 catalytic converters. I bought an aftermarket Y-pipe and new rear catalytic converter and since I was replacing everything new I went ahead and replaced the resonator pipe from the rear cat to the muffler, new muffler, new tail pipeand, 4 new oxygen sensors from Bosch. I put it all together and I could hear a slight exhaust leak between the passenger side exhaust manifold and the y-pipe I disconnected everything moved it around a bit till it fit better snugged it down and started it again and it sounded fine and was running fine, or so I thought. I took it for a short test drive of 10 miles and it ran fine seemed to be doing well I came home parked and it sat for the next 3 weeks while I was out of town. I came back and took it out with a friend to look around and the entire 45 minutes we were out I drove 55 mph on old country roads, it seemed to have a lack of power sometimes so I hooked up a scan tool and saw that my bank 1 fuel trim was around -1% up to +6% that seemed normal, but my bank 2 fuel trim was +18% - +56% going high only briefly and then going back down to the lower +18% - +25% range, I had my friend drive while I monitored it and saw that it would go down to +6% while going up hill and then go back up while on level roads and going down hill it would be in the same high 18-25 range. I decided we needed to get back so I could see what was wrong and as soon as we turned around and made the short 5 mile trip back to my house it started to show an active misfire by the blinking check engine light on the dash which would last for 30-45 seconds then stop for 2 minutes then suddenly start again during this the MAF was going crazy jumping from 12-36 G/S which I barely noticed because I usually don't look at the MAF because I forget about it a lot. I pulled the pending codes when I got stopped and I had pending P0300, P0301, P0302, P0303, P0174 I went and rented a smoke tester to try to find the bank 2 leak and smoked the intake begining right behind the MAF on the intake tube and saw no smoke after 15 minutes pulled the adapter and there was plenty in the system if I had a leak I should have saw it, I then plugged it into an evap port, again no leak, then I thought maybe it's not sealing on the driver's side exhaust manifold to Y-pipe connection I hooked the test up to the tail pipe and again no leak and no smoke anywhere. I waited till the next morning for the motor to be cold again started it up and unplugged the IAC valve to see if it would stumble and it almost immediately died, I let the motor get up to operating temp (my normal idle temp is 190) once it had sat at 190 for 5 minutes I unplugged the IAC again and this time no change in the rpm no stumbling didn't try to die at all. I have exhausted my ideas and knowledge and any help anyone can provide in figuring this out so I can get back to using my truck again without fear of it jumping time again or similar is greatly appreciated as I can't afford much more expenses and I can't afford the $200 diagnostic the local Ford dealership wants just to tell me what's wrong, again thank you all in advance.
