- Jan 30, 2010
- 12
- Utah
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- 2WD / 4WD
- 4WD
- My credo
- Stop skipping steps and get it done right the first time.
I have posted about this ranger before, and it has a kind of long back story to it, so bear with me.....
It my buddies 04 ranger xlt 4.0 SOHC. he started having issues not long after he swapped a motor and exhaust from a 2001 ranger. Its been a while so i could be wrong but here goes...
It started with a P2195 and P2197 and a MAF sensor code. he was out of town late at night so he bought a MAF sensor and threw it in, Which did not solve his problem because it was the wrong one and the part store was now closed. he called me and I told him that I thought it was probably an o2 sensor problem. then i told him to unplug his MAF and drive the last 30 miles to home. which he did. the next day he exchanged the MAF sensor for the correct one and installed it which took away the code for the MAF sensor, but the engine running lean codes remained.
He continued to drive it like this for about 6 months and said that the truck was running great despite the 2 lean codes. as it got closer and closer to emmissions testing time he started trying to fix everything without any knowledge. which is where it all went really really bad. he rewired EVERY connector on the truck...by the end of this time truck truck was not driveable and smoked more than a freight train pulling up a steep hill.
he got a scanner that supported live data from a friend and called me. I walked him through some things and determined that it was defiantly an o2 sensor issue. and he said to me, "yeah, the scanner shows that there should be 4 o2 sensors, but there is only 3 holes in the exhaust". At the time, I didnt know that he had swapped exhausts from the 2001 into the 2004, so i told him "if there are only 3 holes in the exhaust, it only needs 3 sensors."
another 3 months go by and he calls me and ask me if there is anyway i would tow it to my house (100miles away) and just go through it for him. So I did. first thing i did was go through and replace all the scotch lock wire connectors with properly soldered connections and correct all the custom wiring he did, and watched about 20 codes disappear. so first things first I started working on the oxygen sensor problem. by now he has put several different o2 sensors that he snagged from the junkyard in, trying to fix his problem.... so I put 3 new o2 sensors in, that were OEM. (2 of the 3 he had in there were bad 1 was not the correct type) but the problem persisted.... so i posted about it in these forums and did some more research on all data. I found that his 2004 ranger did indeed need 4 o2 sensors. thats when he told me he had swapped exhausts with the engine. okay no big deal, got an o2 bung, drilled hole welded bung installed a 4th new sensor.
truck was now drivable, but a few problems persisted....the K&N filter he installed was WAY over oiled so i washed it out and lightly oiled it, clean the MAF sensor with MAF cleaner a few times. truck was really starting to run good, but still not right. So I smoked it with a cheap smoke machine i made and found a few leaks. sealed them up and the truck was running great... decided that with as many vac leaks as i found, i better do a better test. Took it to the shop at the college i attended (they let me use their resources quit often as I established a pretty good relationship while i was there). put their good smoke machine on it gradually bumping up the psi all the way to 75psi. Not one bit of smoke coming from anywhere. truck now running amazing! I drive it around the small town i live in for 3-4 days mostly lower speeds but i did make sure to get some highway driving in too.... no problems. Friend gets a ride down here and picks up the truck. leaves here and drives 60 miles over the mountains and BAM! p0171, p0174. he drives the last 40 minutes home and calls me the next day and here we still are a month later. almost a year and a half after original problem, truck still cant pass emissions.
So here is what i know has been replaced by him and what has been done and what i personally know about it either from testing or being told.
Pcv valve - new
pcv elbow tubing connections - good - not leaking
Intake Manifold gaskets - Just replaced - new
MAF -New (since i had cleaned the other one)
Fuel filter - new - old one was terrible
fuel leak in line right above exhaust manifold - repaired
Fuel Pressure - KOER 62psi - KOEO drops to 40psi and holds
fuel pressure damper - new because he thought it was a regulator
Fuel pump - he says its new, i have my doubts.
exhaust manifold gaskets - New
ECT - new (both sensor and sender)
4 new O2 sensors hooked up correctly and reading correctly in scan tool data
Cat's - Would say that the scan tool data shows them doing their job.
EGR valve - new
DPFE - tested good. I broke one of the plastic deals where the line hooks up, but was able to JBweld it back on. DPFE still tested good.
TPS tested with spec range
IAC - cleaned and tested by unplugging it with engine running, engine dropped to a steady 500 rpm.
at this point i am at a loss.... not sure what i have missed here. I asked him to go buy a vacuum gauge and the video call me while we test it, but who knows when he will.
He says it take a while before the codes come back after clearing them and that when they set he is usually traveling down the road at higher, steady speeds.
but this is a problem he really needs help with, before he starts re wiring again. lol. its also driving me insane, because i live far enough away that i cant go be there in person, and his truck is no longer licensed so he cant drive the 100 miles to me. All of the basic stuff is done. it is not the pcv or anything related. but im stuck.....
what do you guys think?
Pcv valve - new
EGR valve - new
