alrighty Bois, a new clutch fan came, and it its a bit quieter than the other so that one might have had issues, but all in all, still getting too hot. it likes to heat up a little and sit for about 5 mins, then heat up more and sit at one spot for about 5 min, and it will do this over and over as it creeps us the temp gauge.
One of the first things I did with the truck when I bought it is to buy a bunch of radiator flush chemicals, and flushed it out about 7 times until the water was coming out clear, then added in nice coolant, however the last time I took the engine apart, I drained all the coolant that would come out of the hole at the bottom of the radiator, I let it drain for probably an hour, then I turned my engine over and let it run for a second in an attempt to get all the coolant out then let it sit for probably another 3 or so hours, all in all, only about a gallon came out (though it takes just about 2. and when I went to add more in, it only took about a gallon in, even when I turned the engine over and let it burp out, only about a gallon. so maybe there is a huge blockage. at the bottom.
