niburja
- Apr 16, 2020
- 0
- United States
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
- Total Lift
- 2" front and rear
- Tire Size
- 32x11.50R15
- My credo
- II Timothy 1:7
I just installed a new Optima Red Top 34/78 in my '09 Ranger & encountered a couple of minor difficulties so I thought I'd post my solution for others if they're curious about switching to a Red Top 34/78.
The factory tray is a little too short so I cut about 5 inches out of the middle of the lip closest to the front end so the battery would sit flat.
I drilled one 1/4" hole in each the driver & passenger side existing tray lips to accommodate the "J" bolts that I purchased along with a new battery hold down (see pics) to secure the Red Top as the stock hold down won't work anymore. I sprayed the tray with Flex Seal to protect it then I set the battery in the tray, assembled the new hold down pieces, added a flat washer to each "J" bolt, then cut off the excess threads to ensure the hood closes.
Last, the negative cable wouldn't quite reach so I had to break the clip nearest the front end to get it to mount over the battery
That's about it. All's well and I'm happy with the results.
