Opinions please
Rowanoak88
Burlington, WA
Hey guys. I have had several rangers and my wife and I have finally gotten to a point financially to where I can finally build my current ranger. I have a 1993 4.0l ohv 4x4 Supercab Ranger XLT auto. She is sentimental to me so I don't wanna trade or sell to get a different one. I wanna build a prerunner...ish ranger but am unsure about the engine. Should I just pay the money for a different engine? Or should I build the current one? This will also be my main truck so the project won't be a tear it down until its done build. What should I do guys? Please let me know. Thanks.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,587
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
If it's your DD, that kinda limits what you can do, when, and how much. If the engine is running fine and just needs a little attention, I would just let it be and tackle projects you can when you can afford for the truck to be down.
Rowanoak88
Burlington, WA
What would you do with a 4.0l ohv?
rusty ol ranger
Im a Jeep guy now.
7,431
Michigan
177 CID
sgtsandman
Ham Radio Operator
12,587
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
You'll have to excuse PetroleumJunkie412. He like to cuddle and pet his 2.9 at night.
I don't think there is a whole lot of options available for the 4.0 OHV. Make sure the preventative maintenance is done. The 4.0 OHV is related to the 2.9, so there may be some upgrades and modifications that can be done to a 2.9 that will work on a 4.0 OHV. Take a gander at the Tech Library and the Articles/Resources sections to see what is there. The menus are up near the top of the page.
Clean up or fix any leaks there maybe.
Run a fuel system cleaner like Chevron Techron through the system twice a year.
Make sure the throttle body is clean.
Maybe run and engine cleaner in with the oil before an oil change.
Do the Sea Foam treatment to the valves via the brake booster hose to clean the valves. There are a few YouTube videos on how to do it and what to expect.
scotts90ranger
4,329
Dayton Oregon
2.3 Turbo
The 4.0 is fairly respectable as is, but probably seems gutless with an A4LD, the low rev limit is goofy but with the tall gears Ford likes to use and low shift points they can feel gutless. I had a '91 manual trans explorer years ago and it felt sporty with the shimmed up LS in back and 3.73 gears...
If it were me, I would get the engine mechanically sound, get the suspension set up for the tire size you want to run and gear it lower and probably do a manual trans swap...
Rowanoak88
Burlington, WA
I was wanting to do a tranny swap but i was shut down and told basically i am an idiot for thinking that way. So what tranny should i look for? Also right now my buddy has a very beat up 1998 ranger 2.5 8v manuel just chilling in his yard. He doesnt want it. Someone dumped it there in the middle of the night, a buddy of his. The 98 is beat to shit and only a parts rig. Is there anything that i can utilize on my 93?
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Turbo 2.5 if you feel frisky... Not hard to slap together.
Otherwise, Sarge called it when he said there's a ton that can be done to any of the cologne engines to bring power up.
My 2.9 is in the middle of a forged internals rebuild to be able to handle 21 psi off a turbo or two ✌🏿
scotts90ranger
4,329
Dayton Oregon
2.3 Turbo
The M5OD trans from another 4.0L is what you need, that '98 has an M5OD but it's for a 2.3L/2.5L so doesn't help (integral bellhousing), the dash changed in '95 so it likely screwed with the pedal assembly but I'm not up on the 3rd gens and up body wise...
Why would you get shot down on a trans swap? If from the wife that can be understandable, they don't understand that the A4LD isn't a great transmission, not a horrible trans but does suck power and the shift points aren't great...
scotts90ranger
4,329
Dayton Oregon
2.3 Turbo
Do they make decent pistons for the 2.5L now? last I heard doing anything to the hyperutectic pistons was a bad idea... and something about the powdered rods not being great... that said going that route in a 4x4 still requires a bunch of other parts, sounds like fun though :). Believe me, throwing a little boost on the daily driver Ranger is tempting, would probably up the mileage not using all the horsepower it has...
Rowanoak88
Burlington, WA
No not the wife. We don't treat each other that way. It was some douche on another forum. But as far as the 2.5 goes it had been recommended that i turn it into a2.3l
Rowanoak88
Burlington, WA
My pull apart has a 4.0 Manuel tranny for$192+core charge
scotts90ranger
4,329
Dayton Oregon
2.3 Turbo
That doesn't sound horrible, there's more you would need to do a swap like the brake/clutch pedal assembly, master cylinder, hydraulic line, flywheel and I believe starter as well as engine computer but you can run with the auto computer with codes... The A4LD and M5OD are the same length so no driveline changes needed and your transfer case will bolt up.
Was this on a Ranger forum or just another forum? I don't think any RBV forum would recommend keeping a A4LD for an offroad build... not that it matters, just curious.
