only headlights
rangerdanger29678
when i turn on the headlights the break lights do not turn on when i press on the breaks they do turn on. what could make the lights only come on when breaks are pressed
Well generally I consider it normal operation for the brake lights to only come on when you hit the brakes. I'm sure most people will agree with that assessment.
If however you are saying that you have no rear marker lights, that is a different issue (and filament) altogether.
Assuming only the rear markers do not work I would first check the bulbs, it is not impossible for them to both be burnt out at once.
If none of your marker lights are working I would look at the main light switch. They have a tendency to overheat, and it usually results in burnt pins and non-functional marker lights.
Final note, "break" is what you do to a kit kat bar. Brakes are the things that stop the car, unless you drive like my sister in law. Then the car in front of you is the thing that stops the car.
pjtoledo
2,959
Toledo Ohio
Fords
3.0 2.3
:icon_rofl:
we need a new forum category: best of, by adms08
be sure to acknowledge all the wonderful "contributors" in the foreword
yeah, I'm feelin' kinda spunky this morning
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
Work hard and play harder
Here is a very simple test, turn on your parking light only. If they do not come on, you have a bulbs issue. So are you a kit kat kind of person or Twix? If Twix, left or right?
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
wild guess, tail lights lost their ground and are finding a ground through the brAKe light filament :D
