Why would you run a heavier oil in the winter? I would stick with the 5W-20 like the oil cap says. Using too heavy (and too light) of an oil at any time of the year will lead to higher wear rates inside your engine. I know there's a lot of "common sense" about what people think about motor oil, but the manufacturer specifies it for a reason and unless you've got proof that a heavier oil is better for the engine, you've got no real reason to use otherwise. Stick with the 5W-20
+1 on the 5w-20. I typed a big long response last night, but when I tried posting it, the damn computer shit the bed. So I'll just say, 5w-20 is suitable for that engine in all weather conditions, and you should use it, and only it.
5w-20 turns in perfectly fine used oil analysis in engines designed for it. There is a website called www.bobistheoilguy.com where people (like me ) get UOA's and post the results. If it calls for 5w-20 it will be fine with 5w-20. I wasn't a believer either until I got some UOA's, after that I could sleep at night.
My wife has a 3.0 Taurus that calls for 5w-20, Motorcraft oil got just as good a UOA as Mobil 1 for a 5000 mile interval.
Bottom-line best UOA I ever got was with Pennzoil Platinum synthetic which is a few bucks cheaper than Mobil 1.
These days I pretty much use Motorcraft oil in everything. Hard to beat the quality for the price. It is made by Conoco.
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
