oil pressure timing tensioner brand
dashhho
51
Canada
Mazda B4000 SE
Rockauto does not have any motorcraft oil pressured timing chain tensioners. What is the verdict? Do I need to go to my local Ford dealership to get these suckers? Or are the aftermarket okay?
dashhho
51
Canada
Mazda B4000 SE
Well I'd have to say Im having a really hard time finding a source for the ford ones in Canada. Seems there is a bit of stock in the USA but they wont ship to Canada. Is there chance a dealership might have a few lying around?:cry:
sgtsandman
Aircraft Fuel Tank Diver
12,641
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Cloyes is a popular alternative. That's what I'm running.
dashhho
51
Canada
Mazda B4000 SE
Thanks sgt. I was on the fence between Cloyes and Melling.
Engine has 225k kms so better now than never.
Should have taken the advice to do the front one while I was replacing the thermostat housing but oh well.
Roert42
4,959
Kintersville, PA
Ranger XLT
4.0 SOHC
I’ve put cloyes in both mine without issue.
I have found that you do not need to pull the thermostat to do the front one, but I did have to pull the intake on one of my trucks.
OldBlue61
15
Chatham, Ohio
235/55R17
'Thank God for the man who put the white lines on the highway.' - Michael Stanley
Pardon the dumb question, but is there a recommendation on when the chain and tensioners should be changed? My '94 has 113k miles on it, and since I'm not sure if or when it was done, I'm assuming (I think that is safe in this situation) it hasn't been. I've heard that this is the biggest Achilles heel with these engines - true, or anything else I should watch for?
OldBlue61
15
Chatham, Ohio
235/55R17
The pressurized tensioners should be changed every 70K miles, these are easy to get at with the engine in the truck, if you do this you shouldn't have any issues with the timing chains for a long time. If you don't then the the springs that hold tension on the chains at start up weaken, and the chains will slap on the guides at startup, this causes the guides to break.
Thanks! SO, it sounds like it should hold up for a while after I change the tensioners. Any info or links to a company that makes good quality ones? I can't imagine Motorcraft still makes them...
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
1994 OHV ?
Roert42
4,959
Kintersville, PA
Ranger XLT
4.0 SOHC
@OldBlue61
Dillard is correct, Ignore everything I said. The OHV is completely different motor.
OldBlue61
15
Chatham, Ohio
235/55R17
No problem, thanks for the assist regardless!
For the OHV 4.0, is there a recommendation on when the chain and tensioners should be changed? I don't drive my Ranger a lot, maybe 5k miles a year mostly for working on the property and the occasional run to the lumber yard. Regardless, I don't want to disregard any needed or recommended maintenance.
sgtsandman
12,641
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
We'll have to wait for someone familiar with the 4.0 OHV to come along and let you know. I have the SOHC and never worked on an OHV.
dashhho
51
Canada
Mazda B4000 SE
Do you need to prime the tensioner before install? I see in the videos some people are doing it.
If I do the "accelerator to floor" method and crank the engine for ~10secs will they prime after install?
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
What I found works best is fully prime the tensioners then press most of the oil out in a vice.
If they're full of oil, makes it difficult to get the threads lined up & started properly.
Yes, then do the PedalToTheFloor Prestart procedure.
Roert42
4,959
Kintersville, PA
Ranger XLT
4.0 SOHC
I just did the pedal to the floor for 15-20 seconds with dry tensioners.
