thcscubajohn
- Nov 23, 2014
- Reaction score
- 31
- Location
- Antarctica
- Make / Model
- FORD
- Engine Type
- 4.0 V6
- Engine Size
- 247ci
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 4"
- Tire Size
- 31x10.50r15
- My credo
- Smog is for pussies.
EEC code 157 I think
I had a bad alternator which I changed and still got this code
I cleaned the MAF sensor and the elements looked fine but were dirty so this led me to believe that I have a bad ground or maybe vacuum leak I have checked all the vacuum lines with brake cleaner with the engine running and there was no response maybe I missed a hard to access one or maybe it's because the hinge on the back of my airbox is broken and letting dirty air in?
I also checked the negative cables (grounds) and did not seem to find the problem
Sent from my SM-G930V using Tapatalk
