O2 sensor placement
Junglejoe
66
Columbia Missouri
6.0
Anyone know the best place for the o2 sensors? Getting the exhaust done finally with new pipes from the headers back..
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
As close to the collector as possible for upstream, on the collector itself right before the flange would be ideal but if you don't wanna drill the headers, right after the flange. And as close to the exit of the cat for downstream.
Junglejoe
66
Columbia Missouri
6.0
In the headers wont qork for me.. so after the collector it is.
franklin2
1,758
Virginia
That far down you need to run a heated sensor if you are not doing so now. It needs to get very hot to work correctly. The factory used heated O2 sensors for the same reason, so they warm up and work as quick as possible.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Yup, definitely heated or you'll be stuck in open loop mode for quite a while. If you're running a post 1995 engine/wiring/pcm it should already be setup for heated o2s.
8,370
And put the bung so O2 is accessible once pipes are in place :)
Many stock locations for upstream O2s are almost inaccessible, lol
If its a 1995 or later OBD2 computer it will also want a downstream O2, this needs to be installed after Cat converters
If changing to dual exhaust from single you just need the one downstrean O2 on either exhaust pipe
If it had dual from factory then you would need two, one on each exhaust pipe
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
This statement is absolutely absurd and goes against all known engineering practices.
17,827
SW Iowa
I am an engineer and I support this message.
If you can't put it somewhere hard to get to at least put it somewhere it can catch on stuff and rip the wiring off :icon_cheers:
Junglejoe
66
Columbia Missouri
6.0
2000 pcm. Its at the exhaust shop now..I bought 2 new 2000 explorer o2's, They'll be closer to the headers than before.. so is that good enough?
2drxploder
434
usa
ranger
347
lower
235 on 15s
@Jungle joe, are you only using 2 o2s? who did your tuning?
scotts90ranger
4,367
Dayton Oregon
2.3 Turbo
Technically you want the oxygen sensors at least 2 diameters past the closest bend or junction...
Junglejoe
66
Columbia Missouri
6.0
Yes.. ONLY front o2's . The downstream was deleted. Im on a "start up" tune at the moment so I get it lined out before it hits the dyno. But Bob here in Missouri @ STL Mustangs is tuning it
