O/D issue 5R55E
robbiemohn
Fresno, CA
Hey there folks,
I have been reading every post about this issue for hours and none of them addressed my issue or they did not have a complete thread.
I have a 2000 Ranger 4x4, 4.0 V6 (V.I.N. 1FTYR11X6YPA36711). According to all that I have found, it should be the 5R55E. When I got it (used) the overdrive was finicky but would engage. Now, a few months later that is not the case. All other gears and shifting (including passing) seem to work fine. If I drive for awhile regardless of highway or surface streets, the O/D light will flash at me. The time frame for this happening is random and does not happen all the time. I have read about issues and fixes for just about every other gear/shifting problem on these forums but nothing complete about this one.
Does anyone have any idea what this is or where to start looking? I don't want to just start randomly replacing parts until it works again.
Dirtman
13,367
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
The OD light flashing means there is a diagnostic trouble code for the transmission. It is the transmissions version of a check engine light. Start by getting the truck scanned and figure out what the code(s) is before you do anything.
sheltonfilms
Hoover, AL
Yeah flashing means code but you need to get it read in the same drive cycle. When you key off a lot of the trans codes reset.
Any slipping from 1st to 2nd? 2nd gear on a 5r55e is an overdriven 1st gear.
I bet your problem is torque converter lockup and not overdrive.
Overdrive is just a gear like all the others except it’s ratio is less than 1, so Input shaft is less than output shaft speed.
TC lockup will occurs in the last couple of gears in highway conditions. This locks the input and output of the TC so there is no slip.
When this happens you see a drop of about 200 RPMs.
I bet you are throwing P0741.
I had it and it was the torque converter.
