Nss ???? Ford ranger 2wd m50d-r1
Irokranger93
Michigan
no start of push clutch pedal either go in the garage or few days to find the problem ...
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
THAT is a "Neutral Safety Switch" and your M5OD-R1 doesn't have one, because THAT is the switch for an Automatic.
an M5OD-R1 has the similarly named "Neutral SENSING Switch" which only detects neutral for idle strategy and in point of face if you left the SENSING switch disconnected you'd only ever notice if you had a faulty/sticky IAC.
AD
Irokranger93
Michigan
I bought the peice and no correctly fault of problem
(Clutch Pedal Ignition Lock Switch) $40 motorcraft parts
I Bought eec-iv code reader and detect the error
AD
You understood him enough to answer?
bmonee5
Oregon
serious i was trying to make sense of what this guy was trying to say and i don't understand what he is saying.....
02RangerXLT
53
NE
Well if you would take a look at his avatar...
Insanejughead
33
Missouri
'94, '86
2.3T
Not a good enough excuse. That wasn't written in a comprehensible manner.
Irokranger93, type where we can understand it or expect to get very VERY few helpful answers.
Oh, and I'd like to ask you to please change your avatar. It's sending the wrong message about you to most of this forum.
AllanD
TRS Technical Staff
134
1987... sorta
'93 4.0
This switch is NOT necissary if you you'd just need to rob the shorting bar out of the connector for it in any Gen2 Ranger.Bronco2/Explorer with an AUTO trans (the wiring harness is the sam on both auto and manual)
MY truck has a 5sp trans but I have the jumper in the clutch multifunction Switch, why? because ocassionally I want to run the starter with the truck in gear.
Like when I'm unable to release the clutch due to a clutch actuation failure
(like when the clutch hydraulics take a shit)
AD
TheTopher
176
Delaware
2.3
I always wondered about that, my truck doesn't require the clutch pedal pushed for the starter to crank. I guess the guy who owned it before me bypassed the sensor somehow.
I've thought of that.
Could be. I know the late 90s 'Yotas had a button to bypass it, always wondered why you'd want one.
Kirby N.
March Truck of The Month
