- Apr 15, 2012
- 26
- Brandon, Manitoba
- Ford
- Engine Size
- 2.9
Ok people, I need to ask a question (OMG, NO not a31...
I've got an issue after the truck gets up to temp. (Closed loop mode).
Truck will "stumble" and "fart" while doing highway speed, (1800-2500 in 5th) but ONLY after it's warm, (tach bounces around as well) BUT, until then it acts like it has a supercharger on it, power like crazy, and no tach bounce.
One Other thing, the ALT lamp (beside the engine lamp) "Flickers" some what, BUT, only while letting off on the throttle, if you even "Match" the speed you are doing (or accelerate) the ALT lamp quits flickering.
It's a random flicker, and only when it's stumbling.
the flicker is NOT in time with the stumble, BUT only is present when stumbling with the throttle 'backed off".
TFI is new, Codes in both KOEO off and running KOER are "11"
The only thing I can think of for Diag, is remove the PIP jumper and see if it still does it when warm, this would rule out the ECM and TFI.
Greg
Greg
