TechmanDan
- Nov 22, 2008
- 0
- Chino Hills, CA
- Ford
- Engine Size
- 4.0
Howdy!
I've got a 2002 4.0L V6 4x4 Automatic, 160K miles, with some transmission issues.
Short version, symptoms:
Place selector in "R", no movement, akin to being low on fluid.
Place selector in "D", no movement, akn to being low on fluid.
Place selector in "2" or "1", movement in the correct gear.
Start in 1st or 2nd, turn OD off (button) and shift into D, everything works fine. Stop, proceed to move again, no movement, must shift into 1 or 2 to take off again.
In chronological order:
Bought truck at 74K.
100K: Flush and fill at local trusted mechanic. No shavings, no debris, no issues. Everything ran great!
130K: Flush and fill at same local mechanic. No shavings, no debris, no issues. Still ran great!
159K: Noticed that trans was slipping when shifting from OD to 4th or 3rd, as in passing situation on freeway. Instead of grabbing lower gear, it would just high-rev as if in nuetral. Manually turning off OD got me into lower gear for passing.
After a month of that (I'd say it happened 10 ten times in that month), I was on my way home, stopped at a stop sign. Proceeded to pull out, truck revved, but no movement. Shifted into 2nd, moved along fine. I was able to get it home, and it's since been collecting dust and occasionally running to the hardware store for project materials that don't fit in the car.
Local trans shop says it's the forward sprag. Fluid is good condition, good level. No CEL, all sensors show good reading.
Question:
1) What do you think is wrong?
2) I've got engine teardown and general mechanical (shadetree) experience, and i'm not afraid to tear into this, but as a newbie, what are the risks of opening it up myself?
Question:
