- Oct 6, 2007
- 9
- Age
- 37
- Ford
- Engine Size
- 302
from the sounds of it, abs was doin what abs does
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
You sure it was the ABS? If you hit the pedal and it was solid with no travel at all and no notion of stopping I would say there is something else at fault.
In order for ABS to engage the car has to think it is slipping. It takes you, the OP hitting the pedal to even engage the ABS system.
I don't see how the pedal could be rock hard with no brakes at all being caused by ABS.
Please update when you figure out the problem.
That valve deal in my dad's GMC conked out one day, it had next to no braking power at a decent speed, but would still stop halfway decent at a low speed.the ABS module has valves that are fully capable of stopping the pressure you apply at the pedal from reaching the calipers...after all thats how ABS works. i believe (for what reason i dont know yet) this is what happened. i know i didnt not have enough speed to slide the distance that i traveled before wrecking, so the ABS could not have been preventing a skid...not at idle speed on dry pavement.
Yeah, sounds like something else is wrong with the brakes.in case i wasnt clear, the ABS was NOT working properly in this instance. i was idling along and trying to stop on dry concrete. when i stepped on the pedal, the car just kept rolling forward at an idle like i hadnt touched the brakes.
