No fuel
Scoop549
N.C.
Ranger xlt
Pump good,new relay
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Press button
Scoop549
N.C.
Ranger xlt
Inertia switch good
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
ericbphoto
Overlander in development
16,594
Wellford, SC
3.0L
6"
Don't waste too many words, guys. All these little bits and bytes in the cyber world cost money.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I gives what I gets...
8,370
Unless its a Motorcraft fuel pump "new" just means "NEVER EVER TESTED", new does not mean "it works", so grain of salt any any "new" part
Motorcraft parts cost more because Ford requires each one to be tested FIRST before it is packed for delivery, and the labor to do that kind of Quality Control is expensive, especially since they added that pesky NO CHILD LABOR thing :)
rusty ol ranger
2.9 Mafia-Don
7,492
Michigan
177 CID
Can you hear the pump come on?
Scoop549
N.C.
Ranger xlt
Can jump at relay
Scoop549
N.C.
Ranger xlt
What wire should have 12 v at relay
8,370
Both terminals on inertia switch should have 12volts but for only 2 seconds when key is first turned on so repeat key off and then on to see if you get that 12volts at inertia switch
Gdbeast
Florida
Ranger edge
RonD im having a similar issue. what would be a cause that if I'm getting 12v from the fuel relay but only getting 7.2 volts into the inertia switch thats as far as I've tracked it thus far. I've replaced the ignition completely cleaned all grounds but still no luck.. and I'm not getting power to my obd2 plug to hook up a scanner
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Obd2 plug shares a fuse with the cigarette lighter if I'm not mistaken. Common circuit for a blown fuse.
8,370
There is only 12volts for 2 seconds at inertia switch just after key on, it part of computers Boot up software
After that 2 seconds you will see 5 to 8 volts at inertia switch, that's from the computers monitor circuit, it has no amps just volts, so won't turn fuel pump
So totally normal to see that 7.2v after the 2 seconds with key on
Ford computers only turn on the fuel pump relay for 2 seconds with key on to Prime the fuel system, 2 second run time adds 10psi of pressure
Computer will turn on fuel pump relay full time when it sees RPMs above 400, cranking RPMs are only 200
This is a safety feature in case a fuel line should break in an accident
If fuel line breaks engine would stall, so be below 400RPMs, and computer would turn off full pump relay to prevent fuel from pumping out even with key still on
