Kramerstyle1234
- Feb 7, 2018
- 0
- Ford
I have an 86 Bronco 2, It was unable to turn over and the mechanics had told me there was air in the fuel lines. after getting it back it was parked for 4 hours and then would not start up again.
Am I correct that in the on position the Schrader valve should produce 40 PSi of fuel pressure? Currently there is no pressure or fuel at all coming our of the valve in the on position when i depress it.
I have replaced the in tank pump, rail pump, pressure regulator valve, EEC relay, Fuel pump relay, and it still will not turn over.
Any help would be greatly appreciated,
Thank You
Thank You
