jmabarone
- Sep 2, 2008
- 0
- Ford
Hey guys, I need some help. I can't TL;DR this one, so sorry from the get go. Yes, I have read the thread about bleeding and tried the method by Perfection Clutch and the hose over the bleeder to the reservoir. I cross posted, so please excuse if I repeat myself.
Here is where my truck stands: in the carport in my wife's spot on jack stands. She's not pleased with my lack of progress and is saying bad words like "take it to a mechanic"...
Truck has ~250k miles. Spring in clutch disc broke. No damage to flywheel or pressure plate. Replaced the disc and the slave cylinder since I had the transmission down. I bled the clutch using the "hose from the bleeder to the M/C reservoir" method because there are several loops and high spots in the Ranger system. Pedal would go to the floor except for the last ~1" of travel and clutch would not release.
Next, I pulled the M/C and bench bled it and had a firm pedal prior to hooking it up to the slave cylinder. I bled the system again using the above method. No change to travel and clutch engagement. I also tried gravity bleeding after a good bench bleed on the M/C and it made no difference. I had my wife work the pedal so I could try manually bleeding and it also made no difference.
Next, I pulled the transmission to check 2 things. I thought I might have put the clutch disc on backwards. Checked that and it was installed correctly. Then, I put the old slave cylinder back on because it was working and I thought I may have just gotten a bad part. When I put it back together, I bench bled the M/C again and had a good firm pedal before connecting to the slave cylinder. Again, exact same issues.
So tell me what I am missing... I would rather not just throw a new M/C at it but that's the only other thing I have to yet to replace. As a last resort, I am going to try to manually bleed it again to see if that makes a difference but I really don't expect any different results.
Thanks in advance!
Thanks in advance!
