No A/C?
PNW Ranger
40
Seattle, WA
So I'm one of the few Ranger owners who has a used Ranger where the guy who bought it off the lot didn't want to pay for air conditioning! 1998 Ranger XT. 3.0L V6. Automatic transmission.
9 months out of the year in Seattle, WA - no problem! But what about those 3 summer months? Can I retrofit this otherwise great Ranger with some kind of air conditioning to make those summer more bearable?
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
You could add a factory system
Or maybe look into companies like vintage air.
@19Walt93 has a vintage air system.
maybe he can chime in.
8,370
Yes, you can add AC, its a separate system in all vehicles, electrically it's an ON/OFF switch in the cab
You will need the engine bay parts of a Ranger AC system, Compressor/bracket must be from/for a 3.0l engine the rest of the parts are the same on all Rangers in 1998
1998 was when AC Control was added to the PCM(computer) and the WOT relay was no longer used, but was replaced with an AC Clutch relay
1998 is probably wired for AC, "probably", in 1998 AC was optional on all models, except "Fleet", and if its an option its just easier to include the wires in the main harness vs trying to add them later
This article is a full on factory AC Conversion: https://www.therangerstation.com/forums/index.php?threads/how-to-submition-how-to-install-oem-a-c-from-scratch.160760/
Very detailed
The swapping out of the Blower housing to AC housing probably takes the most time
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
It actually helps with defogging the windows when it rains... so you'll use it 10 months out of the year in Seattle.
superj
2,574
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
My truck had no HVAC system at all so I got a Vintage Air heat/defrost/a-c system. The heat and a/c work OK, the defrost function is lousy because the unit uses recirculated air, so I called them. They're in Texas and couldn't imagine why I'd want to pull outside air into my truck. If you have a functional heater and defroster, they sell an underdash a/c unit that looks like something you'd see in a mid 60's car.
PNW Ranger
40
Seattle, WA
Ron:
Thanks for the link. What I like about TRS is the wealth of knowledge. Adding an A/C system to a Ranger has been done before, and here is a recipe book.
PNW Ranger
40
Seattle, WA
Yes, that is true. It's been a wet and cold spring here in Seattle. Heat and defrost works great on my Ranger, thankfully.
PNW Ranger
40
Seattle, WA
My truck had no HVAC system at all so I got a Vintage Air heat/defrost/a-c system. The heat and a/c work OK, the defrost function is lousy because the unit uses recirculated air, so I called them. They're in Texas and couldn't imagine why I'd want to pull outside air into my truck. If you have a functional heater and defroster, they sell an underdash a/c unit that looks like something you'd see in a mid 60's car.View attachment 75999
Thanks, I've seen these Vintage Air units for sale on eBay, but no instructions on how to install. So I will check out their website.
8,370
You would use a Ranger AC bracket and compressor regardless, so you could use a Ranger AC fan belt
Also I would use a Ranger condenser(the part in front of the radiator), just because you will know "it fits"
Why re-invent the wheel
The "vintage" part is the evaporator setup, so blower always blows air thru it FIRST and then passed the heater core and out to the vents
Evaporator Dries the air, summer or winter, which is why its good to have AC compressor working all the time for better defrost
In any case removing the blower non-AC housing and putting in a blower AC housing in the engine bay isn't all that hard, its just wrench work, a pain but just wrench work, lol
And at a wrecking you might find one where the engine has been pulled out so easier to see whats what when you pull it out, so when you get home the non-AC housing will be a snap...............well at least you will know where to look for all the bolts
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
I resurrected my AC as per the tech article here. Ordered all the parts off rock auto. Running the converted 410a refrigerant. Worked like a charm.
I will admit my buddy who does HVAC used his vacuum pump, nitrogen tank, and freon valve/gauge thingy to make the magic happen. I just did the wrenching.
gaz
654
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
@PNW Ranger ,
If I knew that my 94 parts would work for you and that your 98 parts would work for me (referring only to the air box/heater blower end of things, I would give you my entire A/C system. I have two, 1 from an 87 BII, the other just pulled from a 94 EXP (only missing coolant lines).
