Newer to older rear frame 125".
That would tell me that I couldn't use a regular cab longbox frame under a supercab, even going across generations.
You couldn't do that anyway. The regular cab frame will try very hard to occupy some of the same space at the super cab's rear floor pan and rear wall.
Denisefwd93
74
South East PA
Now thinking
I should have made a separate thread about this. ?
don4331
1,346
Calgary, AB
5.3
I'm in the process of building a 4x4 frame to put under my 2005 2wd. for me the rust issues are on the 4x4 parts, not my original 2wd frame.
I'll try to get some pics of the rear frame sections.
Pics from my long bed super cab; they were meant to show how cab to axle portion is consistent, with an additional 6" behind the rear tire carrier. And how I added 6" to front of frame to get the extra 12" to fit the long bed.
Rear frame section starts ~7.75" past back of cab on short box (13.75" on long); '98 & newer frame in ~6.25" deep at this point, top flange is ~2.25", bottom is just over 2-1/8"
pjtoledo
2,963
Toledo Ohio
Fords
3.0 2.3
C clamps,,, where the hell did all my C clamps go:icon_confused:
Denisefwd93
74
South East PA
I think I'm getting the idea that yes a newer 125 inch wheelbase rear frame will work on an older 125 in rear frame replacement although I can't seem to get anybody to say "yes"!
thank you for the photos! and. yes that's what I envision anybody with welding equipment and lots of clamps, grinders etc is going to be doing.
we built a huge steel cradle for my 10,000 lb sailboat years ago that's when I found out I could not weld and every weld I made was questionable.
ericbphoto
Overlander in development
16,591
Wellford, SC
6"
The best cradle for a boat is water - nice, gentle, evenly dispersed support all around the hull. ?. (except during bad storms)
Denisefwd93
74
South East PA
The extra wide axles were made withFord twin i-beams (the older ones) welded inside of I think it was 3 inch pipe, these happen to be almost 9 foot wide
27719
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Any decent welder knows "Clamps are your friends"
you ain't got no friends? Awwww:sad:
Denisefwd93
74
South East PA
Still looking for somebody to say yes!
pjtoledo
2,963
Toledo Ohio
Fords
3.0 2.3
Denisefwd93
74
South East PA
Don't know if I can bring can bring this drifted away discussion back to my original question can anybody argue that I should NOT get a rear frame off of newer truck with the same wheelbase??????
