Newer cab on an older frame?
BackwoodsSaint
Minnesota
1992
3.0 and 4cyl
Ok, the more that I think about this the more I think it's not possible but I'm way to curious to let it go:
is it possible to stick a newer cab (like, a cab from a 2001-ish ranger) onto an older ranger, such as a 1994? I'm only curious because although I love my truck and have no problems with it, I'd really like to have the rear doors, anyways, a foolish question perhaps, just wonderin
BackwoodsSaint
Minnesota
1992
3.0 and 4cyl
how much would a cab cost? say.. a 2001, no rust or body damage, and an intact interior, manual windows and locks though and how big of a job is a cab transfer like this? what does it involve? what parts would need changing?
alwaysFlOoReD
Forum Moderator
3,781
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Cab cost is what your research will find for your area.
As far as how big a job..... it depends on your definition of big. Some people might call it a cake-walk, others may think it's a job from hell.
I haven't done any body swaps but some things that come to mind are;
electrical - probably have to swap out all of it.
body mounts - rad and front cab mounts should be the same, the rear will be slightly different as they enlarged the cab by a few inches between those years.
exhaust - will have to be obdII compliant so the computer will work properly.
There may be problems with registration as some states don't like to see an older motor in a newer truck.
I'm sure that there is other problems that will crop up but we can give advise as they arise.
Now here are some questions you should answer;
Do you have a place to do this....depending on your skill level it could take a few months.
What tools do you own?
How much money do you have? This won't be cheaper than buying a different truck, especially if you factor in your time.
Are you mechanically inclined? This might be more than you should attempt at this point in your skill level.
Have you done your own brake jobs?
Re and re a transmission and/or a motor?
Front end work?
Are you capable of reading a manual and understanding the electrical section?
Good luck if you attempt,
Richard
Forum Moderator
15,491
SW Iowa
I think if you jump through enough hoops in the right order you can title it as the older truck though.
I saw an '86 BII at a car show sitting on a '67 Bronco frame and the writeup said it had been inspected and titled as the '67 Bronco. It may have been years ago that was done and it isn't possible anymore. Without a doubt both trucks would have to have a good title.
cammeddrz
23
Ford/chevy
efi 350vortec
IIRC the front 4 body mounts are in the same location
snoranger
Forum Stuff Member
Forum Moderator
ASE Certified Tech
12,001
Jackson, NJ
'79,'94,'02,'20
All Fords
That depends on the state. NJ goes by the body... whatever year the body is, then thats what the title is for.
cammeddrz
23
Ford/chevy
efi 350vortec
here in utah they go by the body too.
unless it is a kit car. what the dmv told me when i did mine was, if the body had a vin at any point, that is what they go off of.
but in the case of things like VW fiberglass beach-bodies or the fiberglass ferarri body panels on a fiero etc. they go off of the running gear.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
497
Central Indiana
94 is OBD1 right? A newer cab is going to be setup for OBD2, so all of the electronics would have to be switched out. It would probably be easier to keep your 94 dash (unless you want to try a full OBD2 conversion), but I don't know if the mounts would be the same as a newer dash, so you might have to fab something up.
If your 94 is extended cab, then the cabs should be the same dimensions, but regular cabs got bigger in 98, and would be a lot more work to switch out.
It would be way more work and money than I would want to spend just to have opening rear doors. But it's not my truck.
snoranger
Forum Stuff Member
Forum Moderator
ASE Certified Tech
12,001
Jackson, NJ
'79,'94,'02,'20
All Fords
If we're talking about rear doors.... Its safe to assume we're talking about a supercab.
Keeping the '94 dash would be a TON of work... The entire HVAC system is completely different, along with the firewall.
Forum Moderator
15,491
SW Iowa
That is how it normally is here too, it looked like it was an older build so who knows...
I would very much prefer the '94 hvac setup.
Destroyer000
January 2009 STOTM Winner
MTOTM Winner
7
Plattsburgh, NY
1999
4.0. 4.0 Supercharged
my truck is a 95.. it has a 00 cab 4 door cab on it now.. rear 4 cab mounts line right up. the core support has to get re worked.. the mounts are i believe 2 inches wider on the 00 vs the 95 other than that it was a pretty much bolt in .
BackwoodsSaint
Minnesota
1992
3.0 and 4cyl
Did you have to title/register it differently? How tough was it? How many hours labour?
stmitch
MTOTM Winner
497
Central Indiana
His 95 would be a bit easier than your 94 since it has the newer dash, and OBD2 electronics already. Your 94 is OBD1, and apparantley has a different firewall, dash and HVAC stuff too.
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
What about the wheel base or we just talking the cab ?
Didn’t the Rangers increase the cab length by 3” around ’98, which would increase the wheel base by 3”s ?
