Northidahotrailblazer
436
Northern Idaho
Solid Axle Swap 4x4
8 inches
37"
12 ton harbor freight press and then I added an air over hydraulic jack to it. Hopefully will work great for setting up my gears! Wanted to buy the 20 ton but they were sold out, olwell the 12 ton will do.
Roert42
4,889
Kintersville, PA
Ranger XLT
4.0 SOHC
Careful with the press plates that come with those. Use to be made of cast steel, easy to crack and shatter. don’t know if they still are.
Hunk of AR plate is safest.
Junk Collector
4,704
Rapid City SD
Swag sells some really nice arbor plates but they are spendy.
I ran across a small piece of 1" plate that had just enough meat left to make two arbor plates for mine... I had a full day into building them. Most of that was to cut the stupid round holes, ever used a hole saw to cut through 1" plate??? Takes f o r e v e r but they turned out real nice.
Blmpkn
Toilet enthusiast
6,350
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
I'd really like to get a press brake attachment or whatever for my hazard fraught 20 ton press.
436
Northern Idaho
Solid Axle Swap 4x4
8 inches
37"
I was going to do what Shran did or just use solid stock. We have more than enough 1" or 2" plate at work i can use. All i really need it for right now is push bearing on carriers and pinion bearings. Ill build whatever we need future uses.
Junk Collector
4,704
Rapid City SD
That is on my short list of tools I want too... and the chamfering table from Swag. I have the chamfer tool, just need the table, it looks super handy.
lil_Blue_Ford
5,964
Butler, PA, USSA
4.9L
So… you gonna offer plates for the rest of us? :icon_rofl:
ericbphoto
Overlander in development
16,346
Wellford, SC
3.0L
6"
Bought a new 1/2" drill. My Bosch 18v has given me many years of excellent service. But its gearbox finally wore out. I have been slowly consolidating all my battery stuff to Milwaukee M18. I bought this in a kit with a charger and two 5ah batteries. So, now I have 2 chargers and enough batteries to keep me working with several tools all day long.
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,530
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Setting up gears?
I put the pinion in the freezer to get it nice and cold, put the bearing on a hot plate to get it nice and hot, stand the pinion up, drop the bearing on, and hold the bearing down tight with a piece of pipe until it cools off.
85_Ranger4x4
17,520
SW Iowa
Setting up gears?
I just put the bearing in the oven for the input shaft of my trans, worked great.
436
Northern Idaho
Solid Axle Swap 4x4
8 inches
37"
Setting up gears?
Yes, that will be the game plan. But you never know sometimes it doesn't work. I'm a heavy equipment mechanic for 15 years now. Your not wrong but that doesn't always work.
Putting some thing in the freezer has nothing on liquid nitrogen. I don't like to beat things and if I tried to do it without the press my bearings would just get stuck and id mess them up and buying new bearings. Just my luck anyways......
oldgeek
1,027
USA
Ranger XLT
Being that the former threading bar was slightly modified during an abrupt stop against the part in the lathe chuck (long worded way to say it 'crashed') I had to order a new threading bar.
snoranger
Professional money waster
ASE Certified Tech
13,526
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Abrupt stop and lathe are 2 things that usually don’t go good together.
oldgeek
1,027
USA
Ranger XLT
It makes the tool salesman smile!
And the lathe tech service smile too as it caused the spindle drive controller to fail. That was not a good day.
Kirby N.
March Truck of The Month
