New to site: '07 2.3l, AT, electrical issue
Ltcjc754
Law Enforcement
15
Dudley, NC
New to the site, '07 2.3L, AT plain jane Ranger.
Sat in my truck, prior to starting I heard the "clicking" sound of the 4 way flasher (as if I left it on). Looked at the dash, no flashing arrows, got out to look at the front and rear signals (nothing amiss). Still the "clicking" of the relay. Moved the turn signal lever down, got out saw the left turn signal operating (both front and rear), moved the lever up, again looked and found the right signals (front and back) working as designed. Remember, the keys are in my pocket, no accidental start or power from the ignition. Returning the signal arm to the neutral position, the turn signal went off, however, I could still hear the "clicking". I've never experienced this before so I'm at a loss. Any thoughts or suggestions?
PS: I pulled the 4 way flasher fuse, and everything ceased. No flashing, no sounds, etc. Upon replacing the fuse, the "clicking" returned.
Thanks for any and all input. Chuck
sgtsandman
Aircraft Fuel Tank Diver
11,128
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Thread moved to the electrical section. Someone with an idea on how to troubleshoot this will be along.
Uncle Gump
Token Old Guy
11,876
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I moved the other thread then saw you moved this one... so i just deleted the duplicate.
rusty ol ranger
Im a Jeep guy now.
6,431
Michigan
177 CID
Sounds like something with constant (key off) power is shorting out/leaking voltage over to the flasher circuit.
Ltcjc754
Law Enforcement
15
Dudley, NC
As a follow up: I replaced the "flasher relay" with a new one, the "clicking" stopped for about 5 minutes, then began again. I then pulled the relay (under the dash, left side) and left the vehicle overnight. This morning I went to start the vehicle (with the flasher relay out) and the battery did not have enough juice to start the truck. I got it started and drove it a short distance, no issue other than the "Clicking" both while running and with the ignition off. Still don't know what's going on. Thanks.
Ltcjc754
Law Enforcement
15
Dudley, NC
Can anyone suggest where to find (manuals, etc.) which fuses are "Hot" (ignition "Off") and which fuses are off when the ignition is off. I'm having a possible "ground" fault issue, and am trying to track it down. I have the fuse schematic but can't decipher which are "off" and which are always on. Thanks.
sgtsandman
11,128
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
You could try ebay for a wiring manual. Helm sells new manuals but I don’t know how far they go back. So ebay may be your best bet.
Ltcjc754
Law Enforcement
15
Dudley, NC
Uncle Gump
Token Old Guy
11,876
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
The flasher circuit is hot at all times... the control signal for hazards comes from the multi function switch. I don't have schematics... but does 07 have the HEC (??) In the RH kick panel?
I've heard of some weird symptoms when things happen there.
@RonD would you have anything to offer here?
7,718
2007 and 2008 will have the same wiring, pay attention to the "except 2.3"(1 and 2) indicators, the V6 Rangers and 4cyl Rangers have slightly different wiring
I would unhook battery, then remove the Clam shell covers from steering column and unplug the Multi-function switch(turn signal stalk) wiring harness, then hook up battery and see if the clicking has stopped
Multi-function switches are "the only moving part" in the system so can fail
Yes, the dual flasher unit has two circuits inside one has 12v full time for the 4-ways, and other has key on 12v for turn
It was a good idea to replace that flasher unit first, but I would now check the Multi-function switch
2006 Ranger and 2007 will have the same turn signal wiring, engine model didn't matter
Josh B
1,733
Oklahoma
You are yet to mention the flasher switch on top of the Steering column?
Ltcjc754
Law Enforcement
15
Dudley, NC
What is the HEC?
Uncle Gump
Token Old Guy
11,876
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I meant to type BEC. I added question marks because I wasn't sure of Ford's naming.
BEC would stand for Bussed Electrical Center. Basically a fuse relay center in the RH kick panel area. Seems I remember water intrusion issues.
HEC would be Hybrid Electronic Cluster.
Ltcjc754
Law Enforcement
15
Dudley, NC
Thanks for clearing that up for me.
7,718
SJB(smart junction box) is in/behind the passenger side kick panel, cab fuse box is part of the SJB
It replaced the GEM module(behind radio) as the body computer in 2004 to 2011 Rangers
But 4-way and turn only get their fuse power from SJB its not involved with actual operation of 4-ways or turn signals
The battery drain could certainly be an issue with SJB but wouldn't think that could cause Flasher unit to "click"
