New to Rangers, need some advice
Demersus
Hi everyone. I recently bought a 1990 Ranger Super Cab with a blown 2.9L V6 & good 4-auto. Before I go with an idential 2.9L swap, I wanted to get some feedback about whether the wiring harness, computer, etc, would work as-is for either the 2.3 4-cyl or the 4.0 V6. I wanted a 4-cyl, but this one was cheap and in good overall condition other than the blown motor.
Thanks,
Demersus
It won't work as-is for the 4-cyl. You would also need a trans for the 4-cyl.
The trans should hold against and will bolt to a 4.0. You will need the headlight harness from a 4.0 truck to swap in a 4.0 because the ignition harness is part of the headlight harness.
trail B2
8
North Eastern Ca.
I'd like to point out since your new that the 4.0 offers very similar mileage as the 2.9 and is a much better driving experience IMHO.
Demersus
Hi adsm08 & trail B2,
Thanks for the info and sorry about the noobie questions. I did do some reading in the Technical Library about the 2.9 in general and about a 4.0 swap also.
I'm having a bit of buyer's remorse so I'm leaning towards the cheapest route and buying a used 2.9 for a direct swap, especially since I don't have a shop right now and need to pay someone to do the swap.
However, I'm still curious about what it takes for a 2.3 4-cyl swap. In addition to the transmission, what other things need to be swapped? Is it about as involved as a 2.9 to 4.0 swap?
Thanks,
Demersus
04sd
'90 / '84
4.0 / 4.0
To do a 4cyl swap you'll need engine, trans, under-hood wiring, computer. You also need to make sure the engine has all of the accessory brackets etc. Much easier to just drop in another 2.9. Why the desire for a 4 cylinder, I doubt gas mileage would be much better.
mp3deviant721
24
Eau Claire, WI
2.3l of fury
Mileage won't be as good as you think. That auto transmission and supercab would hold you back from getting 20+ mpg with a 4 cyl. I'd just replace the current engine or do a 4.0 swap. If you want good gas mileage with a truck, get a regular cab, 4 cyl, manual transmission, and 2wd.
TheTopher
176
Delaware
2.3
I managed 28.6mpg on my last roadtrip.
But in a heavier supercab with an auto, I think the four cylinder would be VERY underpowered for him.
Demersus
Hi Everyone,
Thanks for the advice. I'm continuing down the path to find a replacement 2.9 motor. Although I'm now also considering getting a rebuilt long block, but either way the lowest hassle will be going with the 2.9.
Now, as for interior pieces, what years will swap with a 1990 as far as headliner & seat, etc? I've heard it's from 88 to 94, but not sure of that.
Thanks,
Demersus
