New to me piece of junk
Uncle Gump
Token Old Guy
13,452
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Yep... some have some pretty bad rust areas...
Core support... bottom of the doors... the bed...
Did I miss any?
8,369
Welcome to TRS :)
Mikeyboi
5
Canada
Ranger FX4
What's the first thing I should do to this besides tbe obvious fluid changes and box swap?
Uncle Gump
Token Old Guy
13,452
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Depending on mileage... timing chain tensioners
Saddle Tramp
748
Florida
09fx4guy
176
USA
Pre Key w/ #1 Bars
265/70R16
OP- Congrats on the new truck. Mind if I ask how much you paid for the truck?
Check the core support on the radiator, it is probably rusted to bits. Also see how bad the support under the engine is, where it bolts to the front of the lower control arms. That spot is usually hit pretty well with road spray while driving.
Can we get some more shots of the really rusted areas?
09fx4guy
176
USA
Pre Key w/ #1 Bars
265/70R16
UncleGump- I didn't think that the timing chain tensioners were a problem on the later 4.0 engines.
Uncle Gump
Token Old Guy
13,452
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
They aren't... by this time they should have the latest parts.
However an once of prevention is worth several pounds of cure in this instance.
Seems I heard they should be replaced every 75K... although I've never personally seen a Ford recommendation for it.
Mikeyboi
5
Canada
Ranger FX4
Under a grand Canadian. Worst spots are on the undersides of the bed. Seems to be sagging a little towards the front of the bed.
The majority of the rangers here are rust magnets and new boxes are impossible to come by. You can see in the pic posted that the box and cab do not line up.
09fx4guy
176
USA
Pre Key w/ #1 Bars
265/70R16
