Automobilie
- Nov 15, 2010
- Reaction score
- 0
- Location
- Klamath Falls, OR
- Make / Model
- Ford
- Engine Size
- V6 4.0L w/AC
- Automatic
I got a JVC Arsenal KD a615 from my brother for christmas (As well as a set of speakers, but the main ones don't quite fit into the door and I have no tweeter spots), spent many hours trying to translate the wiring from the new wiring of the stereo to the wires in my truck.
I got the speaker wires set up fine. Here's the wiring for the Receiver Wiring Adapter:
Ye-12 volts constant
Or/Blk -not used
Re-12 volts swiched power
Or/Wh-Dimmer
Or-Illumination
Blk-Chassis Ground
Blu-Power antenna
Blu/Wh-Amplifier turn on
It's a 1990 Ranger 4.0L Supercab that was passed onto me from my granddad. It's in very good shape, but the stock radio had a problem with becoming very loud, then quite, then loud again.
The wiring for the truck goes; http://www.therangerstation.com/tech_library/pdf_documents/90_Ranger-BroncoII_base_radio.pdf
I've got the stereo wired up fine and it works great, but it also has a Day/Night mode (You can change the color and brightness between the two, but the manufacturer hadn't figured out to just add am/pm to the clock so it switches at X-time).
Basically, the truck supposedly has two illuminator wires (Though, the diagram has red for both a ground and illuminator and then a separate wire for the illuminator interior lights). There is nothing for the dimmer wire on the truck, so will connecting the 'interior lights' wire to the illuminator input on the new stereo enable switching between day/night mode?
Also, I'm assuming the ignition wire from the truck goes to the 12v switched input on the stereo?
Or/Blk -not used
Or/Wh-Dimmer
Or-Illumination
Blk-Chassis Ground
Blu-Power antenna
