New Rule!
ChrisHelvey
Mazda
To become a Ford engineer and design systems for automobiles, you must first work on a bunch of stupidly designed systems with your own hands until completion. The kind that need cuss words at the people who thought them up. Then, tell everyone why it was stupid and promise you will never design difficult systems that typical mechanics can't handle without a modicum of regular effort.
THIS time, I am referring to the clutch hydraulic system (All of it) on Rangers/Mazdas. They just absolutely couldn't figure out a way to make a clutch line that would not inherently trap air without needing to pull the entire master cylinder and lines and bleed them on a bench as a whole? THEN, put a slave cylinder inside the transmission? I would have liked to have been in the room on that discussion.
Yes, this video works about bleeding the clutch system: http://www.youtube.com/watch?v=HgNTDGwcjZc
That's not the point.
Plus, did you notice in the video about "don't install the clutch push rod in the master cylinder (if you bought a new one), because it will be stuck in there for good and make it very very difficult to reinstall?" I DID, but I was reusing a perfectly good Master cylinder kit with the push rod already installed. Why should I buy a $200+ master cylinder kit, just to make it easier to put in? Getting it out was a nightmare, getting it back in was even worse.
I did it. As the helpful video said, "you CAN beat it if you do it this way." My clutch works perfectly now. WHAT a PITA!
So, new rule: You have to practice mechanics before you get to design anything. So, you have your Masters degree in mechanical engineering? Good. Now take an apprenticeship at an auto repair shop. THEN you can design stuff for us.:annoyed:
Ryannn
13
Carson City, NV
Didnt really read it, just kind of skimmed through your post. Agreed, but then again Ford or an auto manufacturer doesnt care. :icon_rofl:
doorgunner
Lab Rat for V.A. hospital
MTOTM Winner
2009 Truck of The Year
516
New Orleans (8' below sea level & sinking)
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
Yep....Ground Rules are definately needed in several areas:
(as you stated) engine-eers should be mechanics first....
Everyone should have to ride a motorcycle for a month before driving a car or truck...
Anyone who drives drunk should have to drive into a brick wall at 60 mph without spilling their favorite refreshment......
Terrorist should have to participate in one "live Fire" exercise before receiving their diploma....
etc....................
Observer
Instructor in one of my classes (engr) said when a student was asked to "thread" a nut they eventually got frustrated at what it meant and, not knowing what else to do.. ripped a strand from their jacket and started wrapping it 'round said nut. :icon_rofl:
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
I always figured Ford did stuff the way they did because engineering was alway geared to streamlining the assembly process and that as long as the truck works until the warranty expires that is fine. Repair considerations are just pure luck. :D
The clutch R+R that I did convinced of that. The difficulty of the job could have eased by using a hard line with threaded fittings. But 18 yrs down the road and 126 K miles later. What can you expect?
FritzTKatt
4
Ohio
A rusted out hard line with siezed fittings. Requiring a new master and slave anyway.
Who'se the retard that put the Ypipe under the trans/engine mating on the 4.0's? That's so stupid.
MPRanger
Law Enforcement
5
SE Missouri
4.0L SOHC
yep....ground rules are definately needed in several areas:
Terrorist should have to participate in one "live fire" exercise before receiving their diploma....
Etc....................
roflmfao
Amen. I say, at least once a week, "If those idiots had to work on this thing themselves they never would have designed it that way!!"
Mac
183
C. Wisconsin
2000
199
We always had new engineers spend the first two months out in the shop putting the equipment together. After they had a few projects under their belts, they would go out and help the service man do the install. Our best engineers and designers were the ones who worked on mechanical things as a hoby.
Dave
Frank The Tank
43
South
Chevy FTW on ease of working on stuff. Till you get to 95. Then they suck also.
There's a special place in hell for engineers. (Ford is filling it up)
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
My last engine trans combo had an internal slave and with the help of my cousin pumping and me under the truck turning the bleed screw saying what to do out loud, it took 10 minutes to bleed the clutch from dry.
But I will say, it can be a pain in the ass to do and an inconviance to replace the slave if it does go out, seeing as you have to pull the trans and also my old one was between the bell and the trans.
Sent from my SGH-T499 using Tapatalk 2
To a point. But even that is a secondary consideration.
The primary idea behind Ford's design strategy is "how much worthless crap can we cram into this thing and still leave it so at least one cylinder head can be removed with the engine in the car."
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
I've said the same thing myself many times...probably many times in the same day working on the same thing...
nb11
10
South Georgia
2.3l
Truth. Exactly why I'm going to school to be an engineer. My Ranger is bad, but anybody who has worked on airplanes will probably agree that they're the absolute worst!
mk42gunner
Missouri
2.9
The only hydraulic clutch that I ever worked on that wasn't too big a PITA, was the one in my 57 F-100. Even then I thought Ford did a brilliant move by going to mechanical linkages on the later pickups.
Robert
