New PS pump whines
bbbc3
51
Tulsa, OK
2.8 V6
I just installed a new power steering pump on my truck 5 days ago. It whines every time the wheel is turned. When the truck is cold it is fine, no whine. I turned the wheel lock to lock several times to burp any air out but it hasn’t gotten any better.
Do you think it’s a bad pump?
Give it a few weeks. That style pump has a break-in period and the low-fluid whining noise at all times is normal during that time.
O No 3.0!
63
Knoxville Tn
Ranger xl 3.0
I have replace numerous ps pumps on all kinds of ford vehicles. Almost all whine. Sometimes it goes away, sometimes it doesn't.
BlackBII
Ranger Custom
Truck of Month
982
UT
You can try bleeding it with a vacuum pump, it's worked for me.
Go to home depot and get one of these black rubber plug/stoppers; one that fits in the neck of reservoir and seals it off. Drill a hole in it, put in a hose barb, and attach a vacuum bleeder or large syringe. Draw a vacuum on the system and it should pull all the air bubbles out eventually. You'll need to have the engine running and be turning the wheel back and forth.
