New problem. Not surprised.
OneGoofyGuy
5
Ramhurst, Ga
31x10.50x15
1989 Ford Ranger XLT swapped to a 4.0l with a FM146
Will not go into gear. I tried to put it in first, hold the clutch, then crank it, but it's like the clutch isn't engaged. It'll pull the truck forward like the clutch isn't held down.
Rock Auto 5% Discount Code: F9A1A579ACFAD1: October 1st, 2021
3,981
Odd, the FM146 and M5OD-R1 used the same slave, the FM145 was different
I assume you have bled the clutch system and there are no leaks, so its holding pressure, you can feel pressure in the pedal?
Take top off the reservoir and pull out the air diaphragm(rubber cup) have some one push down on clutch pedal while you watch fluid in reservoir, it should NOT move, if you see fluid flow in then Master is bad
OneGoofyGuy
5
Ramhurst, Ga
31x10.50x15
I have bled it but I'll double check it.
Dirtman
13,273
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Have you tried cursing at it?
Ranger850
1,997
Tallahassee Florida
Stock 2"
Stock
91stranger
509
Gets Mo Chicks
These rangers live up to the fix-or-replace-daily motto.
There's two types of rangers out there, ones that are broken and ones that are going to break.
Ranger850
1,997
Tallahassee Florida
Stock 2"
Stock
and the ones that just got fixed
snoranger
Forum Stuff Member
Forum Moderator
ASE Certified Tech
6,645
Jackson, NJ
'79,'94,'02,'20
All Fords
That’s what happens when you buy beat up garbage. I’ve had nothing but good luck with all of my Rangers overs the years. Yes, they do require some repairs... but everything does.
All you seem to do around here is badmouth Rangers and spread poor information... it’s getting old.
91stranger
509
Gets Mo Chicks
What have I said bad about rangers other than what I just posted? You act like no one has heard the saying "fix or replace daily"....
Lighten up dude.
Dirtman
13,273
41N 75W
It's up there.
It's down there.
Round.
Lighten up dude.
Eddo Rogue
559
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
maybe finger(s) broke off or bent on your pressure plate...
3,564
How does the clutch pedal feel when you push it down? Does it feel springy and firm, or is it floppy like an old man's weiner?
3,981
"old man's weiner"??
How old are you?
If you are under 65 then I don't want to know how YOU KNOW what an old man's weiner feels like :)
