New member
JimRogue
Montana
Ford Ranger XLT
2001 Ranger 4.0 L 2WD 354,125 miles automatic
Column gear selector has migrated to the right. Sometimes have to give it a little push in park to allow it to start. Any advice is appreciated.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Welcome to the site. How is your transmission mount?
8,369
Welcome to TRS :)
Google: Ford Ranger loose column shifter
Common issue on Ford trucks with column shifters, usually just 2 loose screws under the dash
Lots of videos about how to fix that and other things that may cause that
JimRogue
Montana
Ford Ranger XLT
Welcome to TRS :)
About 9 months ago the selector became sloppy, found screw on drivers mat, fixed it. But long before that the selector guide migrated to the right; park is at reverse, reverse is at neutral, drive is at 2nd,etc. Was told then not to worry about it. Just recently, park has become a bit touchy and sometimes have to give the shifter a little help so I can engage the starter. I have to say that despite the miles this truck is in very good condition, bought it new, most dependable vehicle I have ever owned. I will check the videos. Thanks
pjtoledo
2,959
Toledo Ohio
Fords
3.0 2.3
there is a bracket on the transmission the shifting cable runs thru. it has an adjustment range to match the transmission with the
gear selector. slide out a white plastic locking tab, adjust the cable, slide the locking tab back in. there are small grooves that the tab captures.
JimRogue
Montana
Ford Ranger XLT
Thanks, I will give it a try and let you know.
