Aadams_4440
- Aug 11, 2022
- Reaction score
- 7
- Location
- Texas
- Make / Model
- Ford bronco ii
- Manual
Hey guys I recently bought a 1987 bronco II as a project. No spark issue. I found the fuel relay had the orange lt blue wire cut and ran under to the frame rail and tied into the same color wire. With the key on the pumps came on for a second. Unhooked coil wire to check spark and no spark. Removed tfi module and ohm tested it. Installed a new motorcraft module. Still no spark key on unplugged the tfi here are the results
Ground cable is on the distributor.
Battery is currently 11.55
1 4.4 volts
2 11.2
3 11.2
4 zero
5 11.48
6 4.0
1 4.4 volts
2 11.2
3 11.2
4 zero
5 11.48
6 4.0
