94' Ranger
- Jan 17, 2021
- 17
- Southern California
- Ford Ranger
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 2WD
- Tire Size
- 15in rims + Falken AT3
My 1994 Ford Ranger 3.0 has been having an electrical issue that revealed itself the other day by catching fire. I had a major direct short on my blk/org B+ alternator wire in between my inline fusible link and the starter solenoid relay. While the truck was running the short was not complete, but when I connected jumper cables with my truck off and sitting still, it started pluming smoke. The short was obvious, there was exposed wire laying on my truck body past the fusible link.
I had been going through both remanufactured and brand new alternators every month or two and was happy to at least identify the problem. I cut away the exposed wire, replaced the fusible link, and warrantied my 4th alternator. I had them bench test it and saw it produced 15.7V, but when I put it in my truck it did not recharge my battery.
I have gone through all the troubleshooting I can find online and my results are as follows:
*13.08V battery with Key Off (charged overnight)*
B+ Alternator wire is 13.08V
Unplugged 3 wire connector (yel/wht, wht/blk, grn/red). - Yellow wire is 13.08V, White wire is 0V, Green wire is 0V.
KEY ON ENGINE OFF
Now green wire (grn/red) is 12.71, same as battery with Key On.
KEY ON ENGINE ON
B+ stud on Alternator is reading same voltage as battery, 12.71V.
My Battery light indicator on my dash is not coming on at any point.
I checked every fuse under the hood and under the dash twice, all of them are good.
There is a third connection to my alternator, a single white (beige cream color) wire that I have seen people call a "jumper wire". None of the troubleshooting I have found has had me test this wire, just inspect it.
I am not sure where to go from here. I've been checking for continuity along every related wire I can get to, everything I've tested checks out okay.
Any advice is appreciated, thanks.
KEY ON ENGINE OFF
KEY ON ENGINE ON
