negative camber after v8 swap
satcom50
Connecticut
Ranger Splash
Hello. I did a v8 swap into my 1996 ranger splash. Runs pretty good I used a 4r70w trans shifted by us shift gen 2 box. The only problem I'm having is real bad negative chamber. It was a 3.0 and i still have the original springs and front end setup. I did rebuild the front end before the swap. Did anyone after there swap have problems with negative camber. any sugestions will be a big help thanks...
Ramcharger90
1,708
N/A na
306, Bcam,
Its normal. You need an alignment maybe changing out to those moog problem solvers camber bolts will help if needed
