Need to convert pulsing positive to a pulsing ground
Curious Hound
Formerly EricBphoto
TRS 25th Anniversary
20,107
Wellford, SC
6"
I would use something like this. (See below) you could even enclosed that in a small plastic electronics project box.
Hyper
ASE Certified Tech
14
north carolina
ford ranger
That actually looks good, gonna be making my own module 🤣
4x4junkie
684
So. Calif (SFV)
2.9L V6
35x12.50R15
Many times I'll just solder parts directly onto the bottom (solder side) of the printed circuit board (PCB). For extremely simple circuits such as this, it eliminates the need for an external board & enclosure for a more reliable installation (obviously for something more complicated I'd use a board like Hound posted). Usually you can find a spot to solder directly to whichever solder pads are nearby... Occasionally, scraping a bit of the green insulative coating off a trace might be needed to obtain a spot to solder it down.
Example:
franklin2
2,018
Virginia
I do not know what shape your harness is in, but apparently in 04 most of this circuit was in the original ECM. Did you have to cut wires or did you just use the wiring harness from the explorer along with the explorer ECU? What I am getting at, originally you had a wire to ground this light to make it blink in the original ECU harness. If you had to cut this wire out of the 04 harness to release the original ECU harness, it may be hanging around down where the original ECU was. You could put your circuit down where ever the wire is located.
You could test to see if you have the correct wire by grounding this wire, it should turn the light on in the dash.
Hyper
ASE Certified Tech
14
north carolina
ford ranger
@4x4junkie. Id love to be able to do that so its not hanging down looking ugly but i am not experienced enough to know exactly where id have to wire it or id just remove the positive connection from the bulb and ground it there and keep the modules positive wire instead
@franklin2. The harness is perfectly fine havent cut any wires and yes in 2004 the ecu controlled the theft light with a ground signal but since im using the theft module for a 5.0 swap it uses positive voltage so it wont work. I did cut the wire under the dash for the theft module before i knew the cluster was positive and the module was also positive but grounding the wire does make it turn on but it stays on
franklin2
2,018
Virginia
Do you think something like this would work? It's cheap enough. I see one warning from a reviewer, you have to hook the load up with the correct polarity or it will not work.
Curious Hound
Formerly EricBphoto
20,107
Wellford, SC
6"
Not a good choice. That is designed for a 5volt on/off signal from a microprocessor (tiny computer). You'll burn it up.
franklin2
2,018
Virginia
Doesn't it say on top of the relay, second picture down, the coil is good for 3-32vdc (on the right side of the relay) and the contacts for the relay are good for 5 amp, 5-220vdc (on the left side of the relay)?
4x4junkie
684
So. Calif (SFV)
2.9L V6
35x12.50R15
I see that too... It looks like it might work, but I'm not familiar enough with it to know for sure (never did get into arduino myself).
The transistor still seems simpler, but I guess that's just me understanding how they work... I can see not understanding something making it more intimidating (maybe is the same case with myself and that arduino relay lol)
Maybe an assembly diagram can help?
Get a small board (like the one Hound posted) and put the parts into it exactly like so:
One that is done & soldered and you have attached your wires to it, use a piece of large heat-shrink tubing (1" or 1½", perhaps, or electrical tape can work too) to insulate it from it's surroundings.
Hopefully maybe that'll make it a li'l easier.
Hyper
ASE Certified Tech
14
north carolina
ford ranger
Looks great and ill definitely do this idea, i do wish i would if been able to solder it to the back of the board
Curious Hound
Formerly EricBphoto
20,107
Wellford, SC
6"
Hyper
ASE Certified Tech
14
north carolina
ford ranger
If this is the anti-theft light that constantly blinks every few seconds when the vehicle is parked, I would not suggest using a mechanical relay there (will be constantly clicking, higher battery drain).
Assuming this is a low-current circuit (looks like it should be if it's LED), a simple transistor & a couple resistors will do what you want:
When voltage is input to the transistor "base" lead through a resistor, the "collector" lead will be switched to ground at the "emitter" lead.
Almost any small NPN-type transistor will work in this circuit. 2N3904 is probably the easiest to find though. The two resistors should be 2200Ω (or 2.2K).
Note that this circuit (diagram attached) is good up to 200mA. (I suspect it'll be more around 15-20mA when it pulses, but check just to be sure)
This right here was the answer theft light works wonderfully now, thank you for the answer, hope your answer will solve other peoples problems
Hyper
ASE Certified Tech
14
north carolina
ford ranger
Before i start another thread there is a plug underneath my ranger that isn't plugged in i did some research and found that this might be the pin layout
Pin 1 Gray/red = ground
Pin 2 Black/pink = reverse lights
Pin 3 purple/white = evap vent sol
Pin 4 brown/white = 5v reference
Pin 5 blue/orange = 12 volts
Pin 6 white
Pin 7 red/pink = fuel pressure sensor
I do not know where the white wire goes as the plug that went to my ranger harness was cut off and i have no way of finding it + the wires that was there aren't the same colors like its ground was a black/white wire and cant remember the others, pins 2,3,4,7 was the same color tho
Curious Hound
Formerly EricBphoto
20,107
Wellford, SC
6"
Not that I'll have your answer, but a good description of where this is and maybe some pictures would be helpful.
And, since it's a different subject, a new thread is advisable.
Truck of The Year
Kirby N.
2024 Truck of The Year!
Vagabond Video
