Need the skinny on brake proportioning and function. '94 XLT 2WD
Eddo Rogue
2,535
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
I just had the same problem. Turned out to be the RABS valve. It was in the frame rail under the master cylinder in the engine bay. a bit tight, but simple swap.
ForgedCrank
128
Indianapolis, IN
2.3
Well, I swapped out the valve. I pulled the downstream line off of it, and zero fluid was passing through. Verified after I removed it, it's plugged up.
flushed out all the fluid again, installed O'Rielly replacement. I do appear to now have rear brakes, but they aren't doing much... which I assume is pretty normal. I think the bias is supposed to be 70/30, but at least i have a little bit of help from the rears now.
I'm going to keep the core and clean it out, replace any o-rings and just have it around.
Eddo Rogue
2,535
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
I ended up doing the same, except exchanged my core via rock auto....ended up w a dorman. It seems to work, but was not finished as nice and I had to clean up the threads to get the threaded straight. I was worried but the brake lines dont leak.
You don't need much. If cant spin the back tire on a jackstand by hand, you got enough back brakes.
If you really want to dial it in, there is a swap to manual adjustment. I think it consists of a T fitting to bypass the valve and manual adjust valve made for mustangs...I read some threads on it but decided to just replace the valve and keep it oem stock setup.
Rick W
October Truck of The Month
Vagabond Video
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
