Need some swap advice
Range98
Pennsylvania
306 with a bunch of mods
I've been wanting more power and rumble from my truck so I'm thinking 302 swap. My issue is I have a really reliable 3.0 l and I don't know how reliable a swap would be. My truck has original engine and trans at 166,000 miles, and no issues I'm afraid if I go through and do it then I might end up in the garage every weekend fixing something. How reliable are your 302 rangers?
Dan B.
January 2012 STOTM Winner
MTOTM Winner
22
Armagh, PA
387 Windsor
You going EFI or carbed?
Where in PA?
Range98
Pennsylvania
EFI most likely, my brothers had problems with carbed engines. Near Philly
Teddyzee
December 2011 STOTM Winner
MTOTM Winner
15
Nova Scotia Canada
5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
If you use an EFI 5.0 HO, you will be just a reliable as stock, and get much better mileage. I'll assume an Explorer 5.0 would have similar mileage and power.
Range98
Pennsylvania
Alright sounds good, I'm looking forward to doing it. How much of a fuel mileage increase is average? I always thought a 302 would bring it down. Right now I'm riding about 16 mpg.
Forum Moderator
15,491
SW Iowa
It really depends on how the truck is set up and how it is driven.
Lowered 2wd trucks get 20-25mpg, a jacked up 4x4 driven like a racecar will be very different.
My lifted brick with a carburated 302 gets about 10hwy, I blame a lot of that on the 3spd transmission. It can't help churning 2700 rpm down the highway...
Teddyzee
MTOTM Winner
15
Nova Scotia Canada
When my engine was stock (5.0 HO, EFI, T5 trans, 1997 Supercab, big fat tires) it would get 25mpg. That's Imperial gallons... so 21mpg for you ;)
For reference, my 2001 3.0 automatic Supercab that I drive for the Winter is currently getting 11mpg in mixed driving. My 4.6 Mustang gets over 35mpg highway.
projectnitemare
8
Osceola Mills, Pa
396W
Cheap, fast and reliable...pick two of three and that will sum it up pretty well. Being you are most likely in the OBDII part of Pa to remain legal without exemptions you will need EFI. If you start with a good running donor and swap all of it over there should be little issue. There isnt' a thing wrong with a carb as long as it's the correct size and tuned. Either way of fueling is reliable. There are many reliable V8 swaps running around so it can be done, but you also need to expect some bumps in the road being it is not a factory offered drivetrain. Start with good stuff and you'll have less issues.
Matt
Dan B.
MTOTM Winner
22
Armagh, PA
387 Windsor
I'm getting that from a 2wd running a stout 351W w/ 10.7:1 CR and C4/3.55's/28" tire. It's even running a bit rich. So if I lean it out a bit the mpg should come up a hair. If I lean on her at alll though....that number will drop....quick!
Range98
Pennsylvania
wow that sounds promising. I think I'll do the swap in Spring when it warms up. I can start stockpiling parts and all. I gotta explore headers and the whole exhaust though, I want some rumble :headbang: It's gonna be a long and educational process.
Jbrown1238
6
Largo, Fl
306
None
EFI is very reliable.
Here is a brief cut & paste from my welcome thread. 93 Splash, 210,000 V8 miles, 23 MPG.
Back in 1997 EFI V8 Ranger swaps were still a little new and build information was a bit more difficult to come by. The internet was just starting to catch on and many of the Ranger forums had yet to be conceived. Things have come a long way over the past 13 years. Now much of the necessary technical info is a few short key strokes away.
The first project was intended to be used as a courier vehicle in and around the Tampa Bay area of Florida. At the time of the conversion the 93 Splash already had 185,000 light duty courier miles. I collected new parts from around the country to include a World Class T-5, Ford Motorsports 5.0 crate motor, new EFI harness, 8.8 rear end with 3:55 gears, etc. At the time I was a bit concerned as Florida still had emission testing. But with a few reservations the project moved forward and the final product was perfect for the role it was designed for. The 5.0 93 Splash rolled through the Tampa Bay area every day for another four years before it was pulled from service. Total distance driven at that time was 395,000 miles, 210,000 miles being after the V8 swap. Some of you from around the area may remember the little V8 ranger with the 1965 Shelby GT350 paint scheme. For those of you who may never have seen it in person you may have seen the photo of my shifter set back used in the Harwood Manual.
Range98
Pennsylvania
JBrown, that's real sweet clean looking truck! It is nice having so much information just clicks away. I'll definitely be back if I need some info. How long did your swap take from start to finish?
Jbrown1238
6
Largo, Fl
306
None
I am currently wokring on a "slow progress" 98 Ranger swap (see link below). The 93 Splash took 60 days back in 1997. That was slowed down because UPS went on strike the day I dropped the truck off at Idle Wild Racing for the swap. I couldn't get parts shipped in to save my life.
http://www.therangerstation.com/forums/showthread.php?p=836026#post836026
Range98
Pennsylvania
that build is coming along nice, I was planning on getting the heads rebuilt. How much that did that set you back?
Jbrown1238
6
Largo, Fl
306
None
The heads, upper intake, and lower intake ran about $600.00 plus parts. I know, it is a lot of money for iron heads. But for the intended purpose of this truck (high mileage courier work) aluminum heads were not the best choice. Most of the money went into the port work. The assembly and other machine work was pretty affordable.
