Need some axle help...
2813josh
9
Mascotte,FL
Ford,Ford
4.0 V6,4.0
Ok. so I just picked up a front diff froma 96 Exploder...thinking I could put it in my 87 BII. Now I'm thinkin I scewed up because I don't see it happening. Wonderin if I'm missing somethin...I know its a D35. So Ive been checking the tech Library and I see its SLA IFS....so am I pretty much screwed since I have a TTB? .......if so anybody interested in a D35 with 4.10s lol. Thanks for any help/advice
mhughes165
9
302
ya, ur screwed, its useless for u, put in in the forsale section here, someone may buy it
2813josh
9
Mascotte,FL
Ford,Ford
4.0 V6,4.0
good call...Thanks man that's what I thought. Oh well
mhughes165
9
302
Little X
SW VA
At least you'll be able to resell it since it has 4.10's. If you had bought one with any other ratio it would basically be a greasy paper weight.
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
Go pick up the right one and throw those 4.10s in it.
It's not completely worthless to you. If you find a TTB D-35 with other gears, you should be able to use that pinion and carrier.
mhughes165
9
302
it's not completely worthless to you. If you find a ttb d-35 with other gears, you should be able to use that pinion and carrier.
it is completely useless they are completely different u cant use them
